Globally "Show all Properties", disable "simplify all instances", is there an API?
  • April 21, 2024
  • 4 replies
  • 472 views
Romanr
previously posted
I wonder if there’s a plugin API for that option, if plugin can be written that will go over components in a file and turn off this option.
Searching API for simplify, there’s no such property?
https://www.figma.com/plugin-docs/search/?q=simplify
I can’t believe that I am writing this. they can’t get this “simplify” working properly and detect if which properties are used or not. This is wasting time of so many people and the only way to get this “feature” right is to write a plugin!
Best answer by tank666
Such an API does not yet exist.
  • Figmate
  • April 23, 2024
Hello @Romanr, Thanks for getting in touch about Simplify all instances! We truly appreciate your input.
I’m going to check in with our internal team to see if there’s an API available for this. We’ll keep you posted as soon as we have any updates.
We also welcome any thoughts or suggestions from other community members!
tank666
  • April 23, 2024
Romanr
  • September 9, 2024
Junko,
You never got back on this. What happened?
Since such API does not exist. The suggestion is to add API or add preference.
  • Figmate
  • September 12, 2024
Hi there, Apologies for the late response.
I’ve also checked internally and we currently don’t have an API for this. Your feedback has been forwarded to the relevant team for consideration.
Thank you for bringing this to our attention!
