Chunkit
Dec 6, 2024 12:57 AM UTC
Font weight variables are not working properly
This is a recent issue with my design system, the font weight changing back to regular when the variables were set to Heavy, but when I try to edit the text, it jump back to Heavy, but it will changing back to regular when I come back to the page next day.
anyone facing the same issue?
it works fine before.
when I not touching it
When I editing the text
Chunkit
ChunkitAuthor
Dec 6, 2024 3:47 AM UTC
here is what it looks like
figma issue (1)
also from the devs computer on dev mode, they are seeing 400 on font weight, and my computer, i am seeing 800
David_R
Dec 11, 2024 3:49 PM UTC
I’m also seeing issues with variable font weights and it’s not allowing me to change the custom weights.
Chunkit
ChunkitAuthor
Dec 12, 2024 3:10 AM UTC
any work around so far?
bhargav_Talaviya
Dec 12, 2024 6:07 AM UTC
If font weight variables aren’t working in Figma, try these quick fixes:
  1. Check Font Compatibility: Ensure the font supports the weight you’re trying to use.
  2. Use Correct Font Weight: Double-check that the weight you’re adjusting is available.
  3. Refresh Figma: Reload the app to clear any font caching issues.
  4. Update Figma: Make sure you’re using the latest version of Figma.
  5. Reinstall Custom Fonts: If using custom fonts, reinstall them or switch to system fonts.
David Alfredo
May 14, 2025 11:22 PM UTC
Recently I face it this issue. This workaround works well for me case:
  1. Select the instance with the problem
  2. Go to the option Reset Instance
  3. Undo the action
This is a little bit manual, but solve the problem.
