AZ1
Apr 23, 2024 8:36 PM UTC
Font Variables breaking font styles
I created variables for weight, font family, and sizes.
In our design library, I updated all our font styles with variables. The variables are listed below.
The problem is that sometimes, the fonts would show up as “Open Sans Condensed” instead of “Open Sans”. The only way to correct it was to break the link to the style and then reapply it. It broke many components and styles where this library was used.
I disconnected all the variables from the font styles and defined them as one would normally. I published the library again. Updated the library within the file and the font on the text was still wrong. The fix is to select the component. Reset changes and then undo.
Not sure what I did wrong or why it broke so much stuff. But, I would like to resolve it as we plan on making several different modes for different accessibility needs and this would save us a considerable amount of time.
Note: Open Sans is not installed locally. The problem occurs on Mac and PC using Chrome, Firefox, and the Figma app.
Variables:
#:Number, T:String
Weights:
#Light | 300
#Regular | 400
#Semibold | 600
#Bold | 700
Font Family:
T: Default | Open Sans
Sizes:
#H1 | 40
#H2 | 32
#H3 | 24
#H4 | 20
#H5 | 16
#Body | 14
etc…
Chelsea_Studenski1
Dec 5, 2024 4:58 AM UTC
This just started happening to me. Our design system needs multi-brand support. I created paragraph styles earlier this month using variables to define the font-family and font-weight, with values defined for each brand using modes. Initially, it appeared to be working. However, things now break when I apply “body/bold” and change to one of the brand modes. Brand 1 (default/white-labeled brand)'s body font uses Semi Bold, Brand 2 uses Medium, and Brand 3’s font uses Semibold.
If I disconnect the text layer from the style after noticing it appears to be “stuck” while trying to toggle modes, I find that it is trying to apply Semi Bold to Brand 2, which isn’t an option for that font, instead of applying the value outlined for that mode.
Alex184
Feb 10, 2025 3:22 PM UTC
Bumping. Currently have a similar font rendering issue with Open Sans. It keeps change Regular to Condensed Regular.
Ive reported it in Figma and opened a ticket.
Stefan Reichert
Feb 11, 2025 10:51 AM UTC
I’ve also experienced this with Open Sans
Using Bold in the component and displays condensed version in any instance. This occurs without any library updates in other files using the library.
The component has the variable ‘bold’ = 700 assigned and looks good
The instance has an error and is not using the assigned variable of the component
If I detach the font-weight variable it shows that it is using a condensed version.
Yuan Tian
Feb 12, 2025 12:20 AM UTC
Hi Stefan, are you using a font that’s managed by the organization/team, or using the local Google font? We’ve seen a problem from users with the organization font, but wanted to see if it happens just with local Google fonts too.
Stefan Reichert
Feb 12, 2025 7:17 AM UTC
Hi Yuan,
we don’t have any fonts installed in our (Enterprise) organization in Figma.
I also have only installed light, regular, semibold, and bold locally on macOS (latest). There is no condensed or light installed.
I’m using the desktop application, but just verified it in the browser as well.
If I deactivate the local installed Open Sans, it works again. I assume it falls back to the ‘Figma cloud controlled’ Open Sans directly from Google. But a lot of users have Open Sans installed on their computer, because it is our main digital font used in other applications as well.
Thanks
Stefan
Christoph_M
Feb 12, 2025 2:18 PM UTC
​@Stefan Reichert ​@Yuan Tian I have exactly the same issue (regular font weight converts to condensed with a font-weight variable of 400) and also reported a bug to Figma today. It worked for over half a year with expressing font weights via number variables. We did not change anything, no new type installation, no new variables. It must have been a thing Figma changed within one of the last updates. At us, it only appears if I create an instance with a font variable in the component attached. If I create a text and apply a font variable outside of a component, it looks ok.
Christoph_M
Feb 12, 2025 2:36 PM UTC
Narrowed it down: for us, it does not happen when applying a text style that includes font weight.
It only happes when breaking the style - or applying individual variables for font-weight at a new text layer.
Christoph_M
Feb 14, 2025 1:08 PM UTC
It has been fixed by Figma yesterday and works again for us. I hope for you too.
Stefan Reichert
Feb 14, 2025 1:15 PM UTC
Yes, works again. Thanks for the heads up.
Stefan
Jun 9, 2025 3:42 PM UTC
Hey All, thank you for your patience!
Glad to hear it’s working as expected again. Please let us know if you run into any further issues.
