AZ1
Apr 23, 2024 8:36 PM UTC
Font Variables breaking font styles
I created variables for weight, font family, and sizes.
In our design library, I updated all our font styles with variables. The variables are listed below.
The problem is that sometimes, the fonts would show up as “Open Sans Condensed” instead of “Open Sans”. The only way to correct it was to break the link to the style and then reapply it. It broke many components and styles where this library was used.
I disconnected all the variables from the font styles and defined them as one would normally. I published the library again. Updated the library within the file and the font on the text was still wrong. The fix is to select the component. Reset changes and then undo.
Not sure what I did wrong or why it broke so much stuff. But, I would like to resolve it as we plan on making several different modes for different accessibility needs and this would save us a considerable amount of time.
Note: Open Sans is not installed locally. The problem occurs on Mac and PC using Chrome, Firefox, and the Figma app.
Variables:
#:Number, T:String
Weights:
#Light | 300
#Regular | 400
#Semibold | 600
#Bold | 700
Font Family:
T: Default | Open Sans
Sizes:
#H1 | 40
#H2 | 32
#H3 | 24
#H4 | 20
#H5 | 16
#Body | 14
etc…
Jun 19, 2024 10:12 AM UTC
Hey! Did you got any solution for the above mentioned issue? I’m also facing the same, please share if any, Thanks!
AZ1
AZ1Author
Jun 19, 2024 1:05 PM UTC
Unfortunately, no. I just had to stop using variables for fonts. Had to manually go back and fix everything.
Alden_Brown
Aug 30, 2024 4:26 PM UTC
Just adding in a comment here to say that I’m also dealing with this issue to hopefully give it a bit more visibility. We’ve spent months building out our design system, and now, suddenly, when I use the styles on other pages, Figma says it doesn’t recognize the font since the font is appended by its weight (ex., “Roboto, Medium”, and not just Roboto). At this point, it would be such a massive effort to try and go back and fix this, so I’m hoping for a solution to show up that isn’t just “redo everything and don’t use this feature anymore.”
stephenjohnston
Sep 24, 2024 11:53 PM UTC
I am also dealing with this. I’ve spent a lot of time building things out and to have fonts change willy-nilly is frustrating for sure. Hoping there is a bugfix for this soon.
Sep 26, 2024 9:47 AM UTC
Hi there! I see in the backend you have filled out a ticket, and the technical specialist is waiting more information to investigate your issue. Please reply them directly via email. For your reference, your ticket number is #1113993.
For others who may encounter a similar issue, I’d also recommend you to reach out directly to the support team so we can investigate further the root cause of the issue on your end. Please fill out this form: https://help.figma.com/hc/en-us/requests/new
Please use your Figma account email, include a link to the file, and add support-share@figma.com as an Editor, so they can take a closer look. Thank you!
kiprou
Oct 5, 2024 2:46 PM UTC
Happening here too. Our font-weight variables (regular, medium, semibold, bold) keep breaking when font-family variable is changed.
Vytautas_Grizas
Oct 5, 2024 8:39 PM UTC
we experience same problems, using font variables such as weight and width breaks everything when trying to edit the text and fonts fallback to closest font weight default value, such as regular or bold and font width resets to default.
Please someone take a look, because using font with variables such as weight and width is in our brand style and we are kinda lost now…
Roman_Bartos
Nov 11, 2024 7:27 PM UTC
Started having the same issue. Font-weight variables is not applied when the text is in style. I need to detach it from the style for the variable to be applied.
Zach_Murphy
Nov 12, 2024 5:01 PM UTC
Any updates on this? It’s still broken on my end and throwing a wrench in everything.
AZ1
AZ1Author
Nov 12, 2024 5:42 PM UTC
I don’t know. They wanted me to send a link to the affected file. But I fixed everything by then.
