Noor2
Nov 15, 2024 7:12 AM UTC
Font Installer Not Working on Figma Web
Hello,
I only use Figma on the web, I can’t use the desktop app due to my computer macOS version. I have installed the Figma Font Installer, and it says that I can use local fonts on the web, but this is not working. Any solutions?
Best,
djvSolution
Feb 21, 2025 3:55 PM UTC
Hey All, thanks for reaching out!
We hear your frustration, but as Nellya pointed out, the primary reason that the font installer isn’t cooperating is likely your outdated macOS. The minimum operating system (OS) requirements is macOS 11 or later. We don't have older versions available for download that support macOS 10.
Julija4
Apr 24, 2025 2:47 PM UTC
I’m running macOS Sequoia 15.4.1 on my computer, but the font installer still isn't working in any browser I’ve tested—Safari, Chrome, and Edge. I’ve already reinstalled the fonts, restarted my computer, and uninstalled/reinstalled the font helper, but nothing has worked so far. Is there anything else I can try?
Same problem, same macOS version, same things tried. Doesn’t look like the proplem is on the user side.
julijacreates.com
Lhmy
Apr 24, 2025 10:27 PM UTC
I installed the Figma App and now it recognizes my fonts in the App.
Princess
May 18, 2025 11:54 AM UTC
Same for me. I tried everything else, but only installing the Figma Mac App fixed it.
silvhua
May 19, 2025 1:23 AM UTC
Same here
KcfromT
May 20, 2025 12:10 AM UTC
also doesnt work for me. There’s a bug for sure.
May 20, 2025 4:04 AM UTC
Hi all,
Thanks for flagging this issue, and apologies for the inconvenience. Our technical quality team would like to investigate further - could you please submit this as a bug report using this link? https://help.figma.com/hc/en-us/requests/new?ticket_form_id=360001744374
When reporting, please include:
  • Your device OS
  • Whether you're using web or desktop app
  • A copy of the font
  • If possible, a link to the design file (you can add support-share@figma.com as an editor, which won't impact your billing!)
Thanks for your patience while we work on this.
Toku
May 23, 2025 1:03 AM UTC
Hi ​@Lhmy ​@Julija4 ​@Princess ​@silvhua ​@KcfromT
Quick update on this issue - our engineering team has identified and fixed a potential problem in the font installer.
Could you please download the latest version from https://www.figma.com/downloads/ and see if that resolves the issue you were experiencing?
This issue is only on the browser app, so it shouldn’t happen if you are using Desktop app.
Please let me know if everything works correctly after the update or if you're still running into problems.
Thanks for your patience!
Toku
silvhua
May 24, 2025 3:32 AM UTC
Toku
I can now use custom fonts on the browser app. Thanks!
Crumb
Jun 5, 2025 8:07 AM UTC
Hello, i’ve had this issue before and found a tool that helped with practically everything in figma.
I just ask what i’d like to do and i get step by step help inside the tools i’m using.
Name is apphug if y’all are interested!
