Tal_Levin1
Feb 9, 2023 10:31 AM UTC
Find and replace text not working
Hi there,
I’ve got a large document in which I need to find and replace a particular phrase. However, when I go to use to use the find and replace feature, it says the text has been replaced without updating the text.
I have to double-click on the text frame again or select and hit return for it to update.
Is this a bug, or am I missing something obvious? Better hitting return, it reads the text as though it’s been updated even though it shows the previous text.
See screenshots below:
  1. Finds text to be replaced
  2. “Replaces” text (note: Figma is not seeing the initial text input)
  3. Updated after double-clicking into the box or hitting return
Jessica_Aceret
Feb 9, 2023 7:21 PM UTC
I’m having the same problem right now. I realized that the replace feature is only changing the name of the layer to match what you put into the “replace” field, but it doesn’t change the text in the UI itself. So that’s why it doesn’t show up again in your search results. Sounds like a bug to me.
martingarnett01
Feb 10, 2023 9:18 AM UTC
Yep! Experiencing this issue too right now. Definitely a bug.
Rene_A_Morales
Feb 10, 2023 6:26 PM UTC
Same here. Thanks Adobe
Andrew_O_Hara_Aidoo
Feb 11, 2023 8:19 AM UTC
I have the same problem.
Tal_Levin1
Feb 13, 2023 5:29 AM UTC
Any updates on this? Is there a way to get a Figma team member to look at this?
Bittle_David_Dave_IPESD
Feb 13, 2023 7:47 AM UTC
Same issue. Please fix this.
Feb 13, 2023 2:42 PM UTC
Same here.
I need to update a prototype with 20 pages with a text that needs changing around 4 times repeated in a page - quite annoying to find out now that it’s not working and I need to manually go update all these texts.
I find this weird because just few days a go find and replace worked fine. Was this after the Figma update that this started bugging…?
Byron_Watson
Feb 14, 2023 9:09 AM UTC
Has anyone from Figma replied?
Byron_Watson
Feb 14, 2023 9:13 AM UTC
So I just double-clicked on the text itself and it appears all texts have updated. Not sure if it’s a fix or not.
bombadillo
Feb 15, 2023 11:34 PM UTC
Having the same problem! So frustrating, as I have over 40 instances of this issue and will have to go through double clicking them all. Could be worse, I suppose. @Figma, this is a bug!
