ROAS Design Squad
Aug 4, 2026 8:03 AM UTC
Figma Professional Team Account Limiting Users to 2 Active Logins — Need Help
Hi everyone,
We’re using a Figma Professional Team account, and recently we’ve started facing an issue where users are being kicked out, and only two users are able to stay logged in at the same time.
This restriction wasn’t there previously, and multiple team members were able to access the account without any issues.
Has anyone else experienced this recently? Is this related to a change in Figma’s login/device policy, or is there a recommended way to resolve this?
Would upgrading the plan or creating a separate account under a new email address be the right approach?
Any guidance would be appreciated. Thank you!
Ahmad_Faizien
Aug 4, 2026 8:18 AM UTC
Hi same here with us , iam not sure why
Finn Tsai
Aug 4, 2026 8:54 AM UTC
Is this a new Figma policy or a temporary bug? An official clarification would be appreciated.
Kartik_Gajjar
Aug 4, 2026 8:58 AM UTC
Same issue we are facing. Support portal is also down today.
Ahmad_Faizien
Aug 4, 2026 9:38 AM UTC
Hello Figma team can you help us please
Ahmad_Faizien
Aug 4, 2026 10:49 AM UTC
​@Celine_
Ahmad_Faizien
Aug 4, 2026 1:23 PM UTC
Hi everyone,
Aug 4, 2026 6:17 PM UTC
Hey everyone, Celine from the Community Support team at Figma here. Thanks for pinging me!
From your description, it sounds like multiple team members are signing in with the same Figma account, which is why some are being logged out as others log in.
It's always a priority to us that you can continue your work uninterrupted. Figma may log out some older sessions if suspicious login patters are identified to prevent security issues or abuse, in line with our Acceptable Use Policy.
If multiple people on your team need access to Figma, the recommended approach is for each person to use their own Figma account and be added to your Professional team with the appropriate seat type (e.g. Full, Dev, or Collab), rather than sharing a single login. This is the supported setup and will help avoid users being signed out unexpectedly. Hope this clarifies!
​@Kartik_Gajjar : Regarding your comment that the Support portal is down today, we aren't currently aware of a broader issue. Could you let us know what error message you're seeing here? Feel free to send us a DM with the email address you're using to access Support, and we'll be happy to take a closer look.
Emerge Digital
Aug 5, 2026 9:01 AM UTC
We are also facing the same issue, so earlier it was accessible on multiple devices but from today, it is not allowing, so please advise if this is a temporary change or  it will be like this and what action needs to be takeb
Aug 5, 2026 9:54 AM UTC
Hey ​@Emerge Digital , thanks for chiming in. Based on what you've described, this sounds like the same behavior discussed above.
As mentioned, Figma may sign out some active sessions when it detects activity that appears suspicious or inconsistent with our acceptable use policy, including potential account sharing.
If multiple people on your team need access to Figma, the recommended approach is for each person to use their own Figma account and be added to your team with the appropriate seat type, rather than sharing a single login. This is the supported setup and will help avoid users being signed out unexpectedly.
Hope this helps clarify things!
Menghorng_Eng
Aug 7, 2026 2:44 PM UTC
Dear Figma Support Team,
We are currently on a Figma Professional plan with an additional Full Editor seat ($192/year).
Recently, we encountered an issue where the user assigned to this Full Editor seat is unable to log in across multiple devices simultaneously due to a session limit (we require around 5–7 active sessions at the same time).
Since this seat is dedicated to a team environment where the user needs access across multiple work computers and testing devices, the current device restriction is creating a bottleneck for our workflow.
Could you please advise if there is a way to adjust or extend the simultaneous session limit for our account? If this is a strict policy constraint, we kindly request that your team consider allowing up to 5 or 7 active sessions per full seat in a future update.
Thank you for your time and assistance. We look forward to hearing from you.
Best regards,
Menghorng ENG
UI/UX Design Freelancer
