m1n3g
Figma Make: React Warning: “React does not recognize the %s prop on a DOM element”
  • March 11, 2026
  • 36 replies
  • 687 views
Both of my projects started showing this warning today while using Figma Make. The warning appears in the console and points to a React issue. Is anyone else experiencing the same issue?
Any insights or solutions would be appreciated.
Best answer by Celyn_L
Hi everyone,
Our Engineering team has pushed a fix and confirmed that the issue has been resolved. Please refresh your files and let us know if you’re still experiencing any issues.
Thanks again for reporting this and for your patience!
Eugene87
I experince similar issues. No solutions so far.
Eugene87
I’ m experiencing persistent React warnings in the console when working with a prototype built in Figma Make.
From what I understand, these props are injected by the Figma preview environment, but React treats them as invalid DOM attributes and throws warnings.
Additionally, the preview sometimes shows visual artifacts and triggers automatic page reloads repeatedly, which makes working with the prototype nearly impossible.
Has anyone experienced this before?
[Moderator note: This post was merged from “Figma Preview Injecting _fgT/_fgS/_fgB Props → React Warnings + Auto Page Reload Loop FIGMA MAKE” into "Figma Make: React Warning: “React does not recognize the %s prop on a DOM element”
I started encountering this yesterday.
My Figma Make freezes on certain elements. I found that it starts to freeze on Dropdown Items, which makes it impossible to work on the interface.
The styles have also changed (some elements have changed color, outlines have been added or removed, which I did not do).
There were also errors like this:
But the funny thing is that when you deploy a project to Publish or Static Files, everything is fine. But when you work through the Figma Make builder, errors occur.
I assume this is a bug on Figma's side.
Same. ​@Andrew_Chan ​@seni ​@Gayani_S ​@Tom Reem
Please can you help us
m1n3g
m1n3gAuthor
I also suspect this is a bug on the Figma Make side.
YuriiV
I am experiencing the same issue just today. Seems like it’s something to do with the update. Although, everything works perfectly fine for other Figma Make projects – the issue occurs only with the one.
Team Figma, please fix :)
Celyn_L
Hey everyone — thanks so much for flagging this and for sharing your experiences.
I’m sorry you’re running into the React warning: “React does not recognize the %s prop on a DOM element” while using Make.
I’ve shared these reports with our Engineering team, and they’re actively investigating. I’ve also created support tickets on your behalf so the team can take a closer look and follow up with you directly.
​@Eugene87 — I’ve located your support ticket (#1789796) and have given it a bump for visibility.
​@m1n3g — your case number is #1790827.
​@Boris Octalysis — your case number is #1790831.
​@YuriiV — your case number is #1790863.
When you get a chance, please share the impacted file with support-share@figma.com and grant “Can View” access — this won’t affect your billing and will help us reproduce the issue more efficiently with Engineering.
Thanks again for flagging this, our team will be in touch shortly with next steps.
Davide Albanese
Hi,
we're having the same problem with a Figma Make project. When I click on a dropdown item, the entire interface freezes. This happens in both preview and full-screen view. Is there support available? Or do we just have to wait?
Thanks a lot
Eugene87
To this problem I can add another one. Now I can’t publish/update my prototype as well. Have some emergency. Hope it will be fixed very soon.
