Amr_Esam
September 3, 2022
External Javascript file for my plugin
I am trying to create a plugin with UI
the problem is ui.html file don’t want to load my ui.js tag
thanks for help
GlebSolution
Power Member
January 10, 2024
this is the answer
Power Member
March 19, 2023
Figma doesn’t load your whole computer onto their servers when you publish a plugin, it only loads the files that are listed in the manifest: code.js and ui.html. It doesn’t care/know about any other files that exist in your file system and how they can be related to your code.
If you need to use external libraries, you either need to bundle them into one file (using Webpack, ESbuild etc.) or use a CDN.
March 19, 2023
What is the way to use external library in ut.html via Webpack? If Webpack will create bundle in dist/code.js I can’t use it as . How can I use some node_modules that I want to access in ui.html with using of Webpack?
January 10, 2024
@Gleb any ideas on what @Yaroslav20 is asking here? I have the same request. Thanks!
GlebSolution
Power Member
January 10, 2024
this is the answer
January 12, 2024
Indeed this (Webpack: see example) works great! Thanks!
