Alisa_Ahtamzyanova
Jun 15, 2023 10:34 AM UTC
Error uploading video: invalid video data
Hello. Has anyone encountered such an error?
video in .mov format does not load, the error “Error uploading video:invalid video data” comes out.
A .webm video with an alpha channel is rendered with a black background. and in the working window it is transparent.
Dec 11, 2023 10:03 AM UTC
Hey,
just had the same issue while trying to upload a video file:
  • .mov format
  • with alpha channel
Figma says you can upload .mov format, but for me it doesn’t work? I tried without alpha channel and it also didn’t work.
Dec 12, 2023 11:57 AM UTC
Hey Max, sorry to hear you are having issues uploading your video in Figma. Yes, you should be able to import in .mov format. Here’s our guide how to add video to files if you want to double check first: https://help.figma.com/hc/en-us/articles/360040028034-Add-images-and-videos-to-design-files#Add_images_and_videos_to_files
If this doesn’t help, please reach out to the support team with your video directly via this form for help: https://help.figma.com/hc/en-us/requests/new Our team can try to replicate it. Thank you!
Cisco
Dec 14, 2023 8:24 PM UTC
This error destroyed my day yesterday. I can’t figure out why but any video I add brings up this error, regardless of if it’s mp4, mov, or webm.
The only exception seems to be screen recordings which are also .mov. I ended up having to screen record the video just to get this done.
Dec 15, 2023 10:16 AM UTC
Hey Cisco,
Sorry for the trouble! Can you please also check if the file you’re trying to insert the video into is currently in your Drafts folder?
Subscription plans are not tied to specific email address, they’re tied to teams. This means that anything in your Drafts is not related to your Professional plan.
Please move the file to a folder in the team’s space that is tied to your Professional plan to add videos.
You can find more info about this in our Help Center “Add video to prototypes”: https://help.figma.com/hc/en-us/articles/8878274530455-Add-video-to-prototypes
Apr 10, 2024 6:39 PM UTC
Hi,
I tried doing it this way and still got an “unsupported file format” error when trying to upload it. Does Figma not allow mp4 files? Very frustrated and confused as to how to troubleshoot this.
Apr 11, 2024 10:29 AM UTC
Hey @Vanessa_Perez-Robles ! Can you make sure the video meets the requirements noted here? Also make sure the MP4 is not an audio-only file. I would also suggest trying different browser or clearing your cache to see if that helps.
Also, do you see any error message?
justin.fraga
Apr 11, 2024 6:22 PM UTC
I have NEVER been able to get a mov, mp4, or any video file imported to Figma with the exception of screen recordings. “Invalid video data” warning no matter what. I’m using AE and Media Encoder so I can export pretty much any format there is.
(Yes, I’ve read your docs page on this, it says nothing about the particular reasons why this happens)
Apr 12, 2024 9:37 AM UTC
Hey Justin,
Sorry to hear you are still having issues. If you have already checked all of this, please reach out directly to the support team and share to them a quick screen recording demonstrating the issue at hand, and please share the .mp4 file you’re trying to upload by filling this form: here. They can test on their end as it may help us to determine what the issue is. Thank you!
May 13, 2024 8:45 PM UTC
Honestly it’s frustrated. I upgraded my plan to be able to add video, only to come here to find out that its the been the normal. I’ve tried all the suggestions you’ve given, all to no avail. Is there an updated solution? smh hmm
May 14, 2024 8:53 AM UTC
Hey @Daniel_ogabi , sorry for the trouble! Usually this happens when your file is not located in the right team (tied to a Professional Plan).
Can you make sure that your file is not in your Draft, but in the team where you have a Professional plan? (to upload your video)
The other workaround is to try to move the file to the team and try uploading the video again.
To move a file, please check out out help center article below:
Hope this helps!
