halkiona
Jun 30, 2023 10:42 AM UTC
Drag direction up and down using variables and conditionals
Hi,
I’m trying to create a temperature picker and recent variables launch hugely simplified the process. I previously has to create a variant for each temperature. I just created a conditional to increase and decrease the temperature. However, I can still only drag the value in one direction only, in this case increase only.
I added two drag interactions one for toggling the temperature up and one for toggling it down but the second one doesn’t work. Is there a way to set drag direction when using conditionals? If anyone has an idea, please let me know.
Thanks
Dec 7, 2023 5:05 PM UTC
Man your prototypes were awesome. I was wondering if there is a away, even if it’s by using a gross workaround, to have decimals in a number variable?
tank666
Dec 7, 2023 6:48 PM UTC
Yes, you can create a number variable with a decimal value. Just enter a period or comma (for example, .25; ,5; 1.4; 2,8).
You can also enter a fraction (for example, 1/10, etc.) and Figma will convert it to a decimal value.
Amalia2
Apr 2, 2024 9:29 PM UTC
I’m trying to use this but for a clock, and changing hours when it gets to 12, for it to change from AM to PM.
So what if I want a range, I want 7 AM-7 PM, on drag. Minutes don’t matter for this. I followed a tutorial for it to all change after a delay but not on drag and tried to combine it with this and got lost. Happy to share my Figma file with you.
tank666
Apr 3, 2024 11:38 AM UTC
In this case, you need to create a couple more variables and add additional conditionals.
For example:
Additional variables:
  • amPM string type;
  • toggle boolean type.
Conditionals:
  minHr = 1,
  maxHr = 12
// minus variant
if (currentTime == maxHr - minHr && amPM == "AM") {
  Set toggle to True
if (currentTime == maxHr - minHr && amPM == "PM") {
  Set toggle to False
// plus variant
if (currentTime == maxHr && amPM == "AM") {
  Set toggle to True
if (currentTime == maxHr && amPM == "PM") {
  Set toggle to False
// default variant
// After delay 1ms
if (toggle) {
  Set amPM to "PM"
else {
  Set amPM to "AM"
As a result, you should end up with something like this:
Amalia2
Apr 3, 2024 9:12 PM UTC
Do you have a link to the file? I also want from 7 AM to 7 PM.
tank666
Apr 4, 2024 10:36 AM UTC
I’ve added a page with this example to the source file (post №4).
Direct link to the design file page:
Figma – 3 Jul 23
The wheel picker component example can be dragged in both directions with an infinite loop of values ​​1-12, and the starting value does not matter here. In any case, you can edit the variable values ​​yourself so that the prototype starts with the value you need.
Amalia2
Apr 4, 2024 5:39 PM UTC
Thank you! How do I make it so it doesn’t go around in a circle? Like I want it to stop at 7 when i scroll up and stop at 7 when i scroll down?
I want the numbers to be
7
8
9
10
11
12
1
2
3
4
5
6
7,
but not be continuous scroll in a endless circle. Like scroll up in one direction and scroll down in one direction, when it passes 12, it changes from AM to PM
When right now if I set the min time to 7 and max to 12, the scroll is
7
8
9
10
11
12
7
8
9…
etc, is there also a way to fix that?
tank666
Apr 5, 2024 9:30 AM UTC
May 9, 2024 10:56 AM UTC
Hey, So I am trying to create a similar but a bit different interaction. I am trying to make a weight scale such that if I drag the scale the number above changes with it. I have attached an image for reference. I tried giving number variable and increasing it as I drag the scale but the scale and number increases unevenly. How can I make it move together like with each line it increases 0.1
