Cristian_Banu
February 7, 2023
Cut text styles
Hey guys,
I’m probably missing something, but hopefully someone can help me understand.
If I wanna copy/paste some text styles from one file to another, I can CUT the text styles from the original file and PASTE them into the new one. But then I have to come back in the original file and hit UNDO, because I never wanted to actually remove the text styles from the original file in the first place.
My question is, is there a reason Figma does this? Why isn’t there a COPY option instead of CUT? Not sure I get the logic behind this.
Thanks 🙂
neha3
January 27, 2024
Figma uses cut for text style to streamline the copy/paste process but it might be more intuitive to have a COPY option to avoid unintentional removal from the original file.
Terence_Curtis
Moving Styles ie cut from one file and paste into another file
Figma Learn - Help Center
conan_galloway
Ctrl + C as well as Ctrl + Alt + C work in the browser but don’t seem to work in the desktop application, at least the Windows version, which might be the point of confusion.
I did find that you can use the Cut option in the context-menu and then paste right back into the same document. Then you can go to another document and paste there as well. Not the greatest solution from a UX perspective but it works.
I do agree that if one option is required it probably should be copy as that’s less prone to accidents.
Cristian_Banu
April 16, 2024
Had no idea it works in the browser, I use the Windows desktop app. And it doesn’t work as you mentioned 🙂
Cutting it is what I do now, but I duplicate the parent file first, because I risk messing up everything. Duplicate, cut, paste, delete the duplicate. Not the most elegant way to do it, but it works.
