Cristian_Banu
February 7, 2023
Cut text styles
Hey guys,
I’m probably missing something, but hopefully someone can help me understand.
If I wanna copy/paste some text styles from one file to another, I can CUT the text styles from the original file and PASTE them into the new one. But then I have to come back in the original file and hit UNDO, because I never wanted to actually remove the text styles from the original file in the first place.
My question is, is there a reason Figma does this? Why isn’t there a COPY option instead of CUT? Not sure I get the logic behind this.
Thanks 🙂
tank666
February 7, 2023
Just copy and paste using shortcuts (Ctrl+C/V).
Cristian_Banu
February 8, 2023
@tank666
Tried it before posting, doesn’t work 🙂
tank666
February 8, 2023
Please submit a bug report to support.
AddWeb_Solution
February 22, 2023
Hello,
You can use the shortcut Ctrl + Alt + C and Ctrl + Alt + V to copy and paste the text styles in figma. (Also from one file to another.)
Cristian_Banu
February 22, 2023
Hi @AddWeb_Solution
Thank for the response, but the problem was copying text styles from one file to another, as in bring text styles from one file to another in the right sidebar 🙂 I think I’m having a bug on my end, so I’ll just use Cut / Paste, hopefully that will get fixed soon 🙂
c.haarmann
January 19, 2024
A colleague of mine copied this way text styles from a published library into another designsystem file. The file she cutted the styles has been connected to a project as the designsystem. After publishing the new designsystem with the pasted text styles, this system with its text styles has been connected to the file I’ve mentioned. It was a mess to clear this issue. So do this carefully and I hope this bug will be fixed soon.
Cristian_Banu
January 19, 2024
@c.haarmann I think the safest thing is to duplicate the file from which you wanna copy the styles, then simply remove it. Beats having to deal with the post bugs.
Terence_Curtis
Related question: when I right-click on a folder of styles there is an option to delete styles and an option to cut styles. What is the difference?
Terence_Curtis
Styles from one file can be published as a library, then added to a new file.
However, you will not see them in the sidebar when nothing is selected. Only when choosing a style from the style drop-down menu.
Styles that show in the sidebar when nothing is selected are called Local Styles.
If your goal is have Local Styles in the sidebar when noting is selected, you will either need to duplicate and modify the original file, or re-create the styles in the new file.
Cristian_Banu
January 27, 2024
@Terence_Curtis
The difference is that cutting styles is the first step in order to paste those styles to another file, while deleting them simply removes them.
