CSS Variable Name differently for Style vs Variable
Josh_Bi
Hi there,
The development provide CSS code with name of color token included. We recently encountered an issue where the name of color token is not always accurate: sometime it shows “–” in front of the name (which is desired), and sometime it shows “—” (with 3 dashes). Please see the attached image.
After some investigation, I found out it may have something to do with using a Variable or Style. Has anyone else faced this issue previously? Is there any suggestion to fix the issue?
  • 2317 replies
  • May 30, 2024
Hi there,
Thanks for reaching out. I’m checking with our internal team. I will get back to you when I have anything I can share with you.
Thanks for your patience.
Toku
  • 2317 replies
  • May 31, 2024
Hello!
Could you share what the name of the variable is? Is there a dash in front of it? We hope to check the patterns.
Toku
Josh_Bi
  • June 3, 2024
Hi Toku,
Thanks for following up. I attached a screenshot which includes both name of the variable & style name. None of them have dash in front of their names.
  • 2317 replies
  • June 5, 2024
Hi there,
Thanks for the details. As I checked about the issue with our internal team, our support team hopes to investigate with your file information, so could you reach out directly to the support team with a copy of your file: https://help.figma.com/hc/en-us/requests/new? Our support team will look into it. My apology that I can’t help much here.
Thanks for your understanding.
Toku
Josh_Bi
  • June 7, 2024
sounds good. will do. Thanks
