Alex_Stoian
Jun 22, 2023 9:34 AM UTC
Create gradients from color library
After the new update we lost the ability to create gradients out of colors from a library. The only option available for gradients is the document colors picker:
Am I missing something?
efrat_kovachSolution
Jul 10, 2023 5:23 PM UTC
Figma engineering team fixed this issue 🎉 Try refreshing Figma.
Equinusocio
Jun 22, 2023 11:09 AM UTC
This is messed up, yes. We lost a feature and the new variables also can’t be used inside gradients.
Figma1
Jun 24, 2023 3:51 AM UTC
And not just gradients, if we want to create a special pairing to go with a brand color based on the brand color we have to dig through the styles, apply it, unlink it, then we can finally use the colors. Before this update we could just pick the library colors where the document colors are. And it made it easy to see what the hex values are. Styles, it’s all hidden behind some locked bubble that you can’t interact with other than to activate it. Annoying.
Thong_Nguyen
Jun 24, 2023 8:29 AM UTC
Figma stated that users can’t use complex color combinations, including Gradient and Color blending mode. But the style is the same as usual with the layout has been revamped a little bit.
Here are their words about this subject.
You can check out this post: https://help.figma.com/hc/en-us/articles/14506821864087-Overview-of-variables-collections-and-modes
Thong_Nguyen
Jun 24, 2023 8:40 AM UTC
Regarding creating a gradient style and adding it to the library, you can see the image below
Petra_Skubin
Jul 4, 2023 5:27 PM UTC
Agreed, very annoying. A bunch of extra clicks for not even being able to replicate the workflow of selecting library colors when building gradients. Not a fan of the new color menus. 😕
Kuka
Jul 4, 2023 7:52 PM UTC
Appreciate the insight to the changes, @Thong_Nguyen but I don’t think it fully captures the issue of this post.
I’ve stumbled on the same limitation as Alex, as before I could create custom gradients by using colors from a shared color library. The workflow isn’t associated in any way with variables, it’s more about the on-the-go gradient tab within the color picker panel.
There used to be a dropdown where it says “Document colors”, where you could select any shared library to get colors essentially from any other external document, which makes sense. The recent update is a huge step backwards which is all the more frustrating 😩
Could someone from @Figma_Support weigh in what’s the story?
Equinusocio
Jul 10, 2023 7:08 AM UTC
Also, the “old” styles can’t have modes, so… is a half-implemented feature IMO. If they really want to use"dark/light" themes as use case for variables, well, it doesn’t work since also gradients, styles, shadows etc should be based on themes.
Alex_Stoian
Jul 11, 2023 10:38 AM UTC
Amazing!! Thank you for letting us know!
Jerod_Guillen
Mar 1, 2024 9:54 PM UTC
As far as I can tell, this isn’t fixed.
