Mads_Maarup
Jun 3, 2021 11:44 AM UTC
Conflicting property values
I have an issue with my library, I cant push updates on buttons because I have a Conflicting property value but I got no idea where this “conflict” is.
Can somebody help me?
Thalane
May 31, 2022 1:23 PM UTC
Hello peoples, I still have this problem, I have variants that are certainly different, but the problem persists from Desktop to Mobile and from Large to Medium, there is always a conflict that I cannot resolve
Enrique2
Jul 8, 2022 7:04 PM UTC
I have similar issue with current Variants while working on Icons. See SS attached
3. Advance Input System (Part 2)-Error_2022-07-08.
Advise Needed!
Katharina_Clasen
Jul 25, 2022 3:29 AM UTC
Wow, why didn’t I check for this? Thank you so much! This was EXACTLY my problem. And I was like: “Conflicting Variants? Everything is correct!” But if you don’t check for a duplicate stacked on top of it, you will never find the error 😊
Jul 1, 2023 9:53 AM UTC
Thanks a lot!
I had the same issue. I checked my property names and they were all the same. I had to give them different names.
Nicole_Coleman
Jul 1, 2024 3:11 PM UTC
I’m having the same issue, but none of the solutions seem to be working. Here is copy of the file. Can anyone see what I am overlooking?
Figma – 1 Jul 24
Gayani_S
Jul 1, 2024 3:34 PM UTC
Hey @Nicole_Coleman, thank you for reaching out!
The following article explains this error: Add properties and values
All variants within the component set will use the same properties and values, but each variant needs to be a unique combination of them.
If any variants have the exact same combination of values, Figma will let you know that there is a conflict. You’ll see this error even if the variants themselves are visually different.
To resolve this issue, you’ll need to add or update the values of the affected variants, so they have a unique combination of values.
Please let me know me know if there is still any issues after trying the above.
Thanks in advance!
Nicole_Coleman
Jul 1, 2024 4:58 PM UTC
Thank you. As far as I can tell and have repeatedly checked, each variant is a unique combination, which is why I can’t figure out the issue.
tank666
Jul 1, 2024 8:42 PM UTC
But the error says the opposite. I also checked your file and immediately found conflicting variants (with non-unique property values).
In the screenshot below, all conflicting variants are selected:
Nicole_Coleman
Jul 1, 2024 10:54 PM UTC
Okay, I did overlook a couple. But not all of them were conflicts. The others I was able to drag out of the component set and back in and that seemed to fix the error. Thanks for taking a look.
Aug 12, 2024 8:50 PM UTC
In my case I forgot I hid original variants via the visibility action (eye icon) instead of deleting them.
capture-2024-08-12-NmLaO2Wz
