jonoyoung
Component with Nested Absolute Position Inside Auto Layout Not Respecting Layer Order
  • February 14, 2023
  • 2540 views
SUMMARY:
In UntitledUI, the dropdown menus use absolute positioning to position the “Open” state menu that appears. As you can see in the GIF below, when the menu expands (exposing the absolute position dropdown) the menu goes behind the other elements in the auto layout stack. It does not matter if the ❖ input dropdown’s position in the layer stack has no impact on the result.
STEPS TO REPRODUCE:
  1. Create a ❖ component with an absolution position element in side of it
  2. Add the ❖ component to a frame, and add an item above and below it
  3. Apply auto layout to the ❖ component and the two other elements
  4. Make sure the ❖ components absolution position element is shown
EXPECTED RESULT:
I expect the ❖ component and all elements inside of the ❖ component to appear above any element that is below it in the layer stack.
ACTUAL RESULT:
The ❖ component’s absolute position elements are appearing below the other elements in the auto layout stack.
DEMO:
absolutePosition-in-autoLayout
How are you working around this? How can we use Absolute Positioned elements in combination with Auto Layout?
Best answer by tank666
tank666
tank666Solution
February 14, 2023
jonoyoung
jonoyoungAuthor
Thank you @tank666. I had not seen that setting before.
For anyone who finds this thread, here is how to find Advanced Auto Layout Stack setting
A UI can be designed. A UX can be measured.
