tcldr
Sep 1, 2022 2:55 PM UTC
Component scaled element not inherited by instances
I’m creating some icons with a base resolution of 1024 x 1024.
Each icon design variation is created as its own component at 1024px.
Then, I have some components which contain those icons where those icons are scaled to different sizes depending on the treatment. (60px, 72px, etc.) In order to maintain the icon design at various scales, I use the scaling tool accessed via the ‘k’ key.
From within the main component (non instances) I can then swap the scaled icon for any other icon component and the scaling applied by the ‘k’ tool is maintained.
However, when creating instances of the component, and then attempting to swap the inner icon instance in exactly the same way as I do within the parent instance, scaling is NOT maintained.
I’ve attached a video which demonstrates the issue:
https://imgur.com/F2wLXJd
In the video, I’ve created two example icons. The first icon contains a series of grey capsules which should be scaled. The second icon is exactly the same but with yellow capsules.
The icon-01 component has been placed within a new component and scaled to 60px with the ‘k’ scaling tool. As you can see in the video, when the inner icon instance is swapped within the parent instance, the scaling is maintained and the capsules are correctly scaled. This is the expected behaviour.
But, when performing the same operation from a child instance, the scaling is lost and the capsules are rendered much larger than expected.
Is this a Figma bug or is there a way to do this?
I’ve heard workarounds of using the ‘scale’ constraints all the way down, but 1) it hasn’t worked for me, and 2) it shouldn’t be necessary as the top-level scaling should cascade down (as it does within the parent component).
tank666
Sep 1, 2022 3:15 PM UTC
tcldr
tcldrAuthor
Sep 1, 2022 3:18 PM UTC
So the only way to do it is via flattening? Seems like a bug as the behaviour does seem to differ between child/parent.
tank666
Sep 1, 2022 3:48 PM UTC
Flattening is required in order for the stroke weight to be correct when swapping different icons.
Could you share a link to a file with a couple of your icons so that I can see their structure and test?
tcldr
tcldrAuthor
Sep 1, 2022 3:55 PM UTC
Thanks for the workaround ideas. The flattening technique works for some types of components, but really I’d prefer a non-destructive method so I can easily tweak the design if I need to.
I’ve filed a bug report. It seems unlikely that the component instances are supposed to behave differently from their parent instances – and that’s what’s currently happening.
In the meantime, I’ll just have to workaround it!
Thanks again.
Dennis_N
Power Member
Jan 9, 2024 10:07 AM UTC
We are facing the same issue so it seems this issue still exists 😕
Damian_Oczki
Jan 9, 2024 2:30 PM UTC
It has always worked like this, sadly.
I’m facing the same issue when trying to create a generic component with swappable instances. If I need to change the icon or illustration, all possible instances have to be the exact same (final) size; otherwise, the layout breaks.
This limitation requires me to create multiple copies of the same asset (big, medium, small, etc.), so that they can be used in components of varying sizes.
I wish the scaling of the original instance was preserved after swapping - or, even better, if there was an option to either preserve the scaling or use the original one.
claud_gp
May 2, 2024 9:51 AM UTC
I’m having the same issue where the scaling is not preserved. Realised that this issue was posted about two years ago. What was your solution in the end please? Did anyone get back to you re your bug report?
Would be amazing to hear what advice you might have on this @Gleb 🙏
Power Member
May 2, 2024 1:00 PM UTC
Does this help?
claud_gp
May 2, 2024 1:57 PM UTC
Thanks for responding. I have mirrored the structure you have set out in the file + applied it to the components I’m working with. I still find that the “scaled size” does not get retained.
I have created a demo of the issue I’m dealing with, please could you tell me where I’m going wrong?
Figma – 15 Jan 24
Power Member
May 2, 2024 2:37 PM UTC
Ah, this seems to be the reverse of the issue: you want the size to change depending on what is swapped. This is possible with one limitation: the sizes of original items need to match, both height and width. You don’t need auto layout as I suggested above as it does the reverse of what you want.
Instead you simply need to set the constraints of the item you want to be resized to Scale. Here is a demo file: https://figma.fun/3wsgwY.
The only issue is the items need to match both width and height otherwise they will be resized not proportionally. The only way to work around that is to use a fixed aspect ratio resizing hack. I don’t know much about it but you can find some examples in the Community. Here are a couple of files made by my friends that originated this hack:
Figma
I haven’t tried but it should work I think.
