Clement_Bettini
Jun 5, 2021 4:29 PM UTC
Change Properties Variant Order
It would be great if we could put the properties in the order we want in the variants.
With drag and drop like layers.
Have a good day 🙂
Marc30Solution
Mar 5, 2024 4:32 PM UTC
OMG I am sooo glad to have found this out! It’s been driving my OCD nuts 🙂 It wasn’t easy to find.
You have to hover your mouse over that little area on the left to get the hand icon to show up but then you can drag. It might be handy if the UI had the little “grips” visible all the time.
tank666
Jun 5, 2021 6:28 PM UTC
Dave19
Dec 9, 2021 7:59 PM UTC
How do you change the order of the variants within the properties?
Eg.
to Size: S, M, L, XL
UPDATE - I see that you can drag the pills around (that wasn’t obvious - but it works)
Martin_V
Nov 23, 2023 9:27 AM UTC
  1. Find your main component
  2. Navigate to the properties panel (right side panel).
  3. Find the variant property and click edit property.
  4. Redorder list position of variants as you see fit. This is the same list order used used to navigate and swap variants on a child component.
Nov 23, 2023 11:10 AM UTC
Thank you! This helped. The original solution was changed in an update, apparently.
Marc30Solution
Apr 2, 2024 7:54 PM UTC
I created 23 properties to easily edit a table (one property for each text), but when I copy the component to use, was without the order planned and I don’t know how can I fix that
Apr 2, 2024 7:55 PM UTC
All properties
Marvin-aedifion
Oct 9, 2024 10:12 AM UTC
This got even less noticeable in the new UI, FYI design folks.
Nicky_Grunfeld
Oct 10, 2024 12:39 PM UTC
With the changes I can’t figure out how to change it. Can you help me out?
jo1
Oct 16, 2024 12:51 AM UTC
i can’t figure out how to reorder the boolean properties in a component? It used to be easy and now it seems there is no way? so annoying! i have to delete the properties and then add them back in in the right order. c’mon Figma
