Jan 22, 2024 8:55 AM UTC
Card component not resizing correctly on hover mode
Hello!
I created a card component with various items. The problem is that when I have a longer title, I can set the card height of the others two to match the longer one but once hovered, the card goes back to it’s initial size which is way too large because of the elements that I’ve added but hid them with boolen.
Does anyone know how to make a card component that resizes automatically when in default and hover mode?
Jan 25, 2024 8:55 AM UTC
Hey Raphael! Thank you for your help!
The rectangle I used for the card seems to be stuck on fixed and Left and Top constraints. Both are greyed out 😕
Raphael_M
Power Member
Jan 25, 2024 10:07 AM UTC
Yes. You will have to edit it on the main component directly. 😀
Jan 25, 2024 8:03 PM UTC
Still cant figure it out xD I want to set a fixed height in Default mode but then when I Hover over it goes back to the large size as if all elements are there and not hidden by boolean (and also not respecting the fixed height I set for the Default mode)
Raphael_M
Power Member
Jan 26, 2024 3:28 AM UTC
Hi, Bogdan.
Because you’ve been using instances you will have to get your height fixed directly on the main component. You won’t be able to modify the subsequent layers of your instance.
What you do is set the fixed height you want on the Desktop card text layer. After fixing the height, set all the subsequent layers’ heights to fill.
> Note: Do this directly on the main component. Do it on both default and hover mode
