Jan 22, 2024 8:55 AM UTC
Card component not resizing correctly on hover mode
Hello!
I created a card component with various items. The problem is that when I have a longer title, I can set the card height of the others two to match the longer one but once hovered, the card goes back to it’s initial size which is way too large because of the elements that I’ve added but hid them with boolen.
Does anyone know how to make a card component that resizes automatically when in default and hover mode?
Jan 23, 2024 3:32 AM UTC
Hi @Bogdan_Iordache, Thanks for reaching out!
I tested on my side, I applied a [While hovering] prototype trigger to a card instance, but hovering outside the card doesn’t seem to reset the state automatically.
I think one option for the workaround here might be to add [Mouse leave] prototype triggers in addition to the [While hovering] on the card. Would you mind giving it a try to see if it works for you?
Here are some related articles from our help center:
https://help.figma.com/hc/en-us/articles/360040035834-Prototype-triggers
https://help.figma.com/hc/en-us/articles/14506587589399-Use-variables-in-prototypes
Hope this helps! If anyone else has alternative ideas, please feel free to share them!
Jan 23, 2024 9:16 AM UTC
Hey Junko! Thank you for your answer!
I don’t have a problem with the hover function when im not on the card. The problem is that when I hover, the card goes back to its initial size with all the elements on it, even tough I applied a boolean and the elements are hidden.
I use auto layout but it wraps around all the elements in the cards even if they are hidden by the boolean.
Raphael_M
Power Member
Jan 23, 2024 9:27 AM UTC
Hi, Bogdan.
Is it possible for you to share a video of this or share a copy of the file? I’m quite intrigued with it.
Thank you!
Jan 23, 2024 9:57 AM UTC
Here is a video. I’ve now used fixed heigh for the card when in default mode but once I hover, it hugs all the elements in it although they are hidden.
mo_hamwi
Jan 23, 2024 11:30 AM UTC
can you share the file ?
Raphael_M
Power Member
Jan 24, 2024 2:26 AM UTC
Hi, Bogdan.
Will you mind sharing the file? I just need to confirm something about the prototype and the components.
Thanks!
Jan 24, 2024 3:45 AM UTC
Hi @Bogdan_Iordache, Thanks for replying and appreciate sharing the video!
Could you please include the whole window, showing the properties and layers panels and relevant layers expanded?
Or, as @Raphael_M and @mo_hamwi have said, would you mind sharing a copy of your file?
That will help provide us with more visual context.
Thanks for your help! Look forward to hearing from you!
Jan 24, 2024 11:58 AM UTC
Jan 25, 2024 3:09 AM UTC
Hi @Bogdan_Iordache, Thanks for sharing your file! I’ve been looking into this internally and will provide an update once I have more information to help your situation.
In the meantime, if anyone else has any ideas, feel free to jump in!
Raphael_M
Power Member
Jan 25, 2024 4:29 AM UTC
Hi, Bogdan.
Thanks for allowing us to see through your prototype.
If I’m not mistaken, the hover effect that you want is something like this?
After checking your nested layers, some layers of your Desktop card text is in fixed height and fill. You will need to put all of the Card text frame and its subsequent layers to hug in order for this to work.
Aside from that, you may also opt to change the rectangle you used for the hover effect and set the constraints to left and right and top and bottom in your main component so the size will follow the card size.
