Nisha_Huston
Aug 27, 2024 1:42 PM UTC
Boolean variable reseting text in an instance in prototyping mode
Hi community! I’ve been having this issue for almost a week now and can’t resolve it, I’ve watched many tutorials in case I find the answer but I haven’t.
This is the original component and has a text property to be edited directly in its instances
I used instances in this card
this card is placed on top of the page and when I click “I’m in” or any other button, it moves to a section that appears containing other similar cards
and they are supposed to appear there keeping the same boxes checked as the one I checked on the main card on top of the screen before sending it to the button section.
I’ve created separate boolean variables, one for each bullet, false by default to match the unchecked box.
and applied the variables accordingly in the instances on the card as you see on top, in the “checked” property.
But when I check any bullet on the main card in prototype mode it resets the text property to the component’s default. (Just in case I went to the instance’s layer and double-clicked the layer’s name to remove the default naming due to this property which was “Manual updates” but still…)
any ideas? am I using this wrong?
Nisha_Huston
Aug 27, 2024 2:19 PM UTC
Also I tried it differently and another issue came in:
Instead of applying the variable to the boolean property in the main card, I applied on to the interaction the “set variable” Location 1 to true
Then in the prototype, in that way it keeps the text property perfectly, and it changes the other cards checkboxes to true, BUT if I turn back to false in the main card the checkboxes on the other cards remain checked.
I also tried adding the “set variable” to false into the interaction of the true variant in the main card component but didn’t solve it.
I’m having this exact same issues in other different functions of the app I’m trying to build
