matko13
September 28, 2022
Boolean property message "not used within component"
  • September 28, 2022
  • 11 replies
  • 29381 views
Hi there, I have a problem with creating and applying a boolean property.
I have a button that is created with nested components. I create a boolean property on the top level of a component to show an icon-only button variant. Still, when I want to apply it to the variants, it’s not visible there so I get an error that says the property is not used within a component. Does anybody have a similar problem? Screenshots attached.
tank666
September 28, 2022
matko13
matko13Author
September 28, 2022
I found a different solution - in my case, instead of boolean property, It can be done by applying a true/false variant.
Matt_W
I have the same question/problem. The issue is that there is no intuitive way of applying the boolean property to a variant.
If there’s a help article for how to use this please can you add the link to it?
tank666
December 20, 2022
November 28, 2023
You have solved my problem with this practical short video ! Thanks 💛
Pavel_Pavlyuchik
February 20, 2024
Just select component instance inside your component and press at this Zalupka
Screenshot_4
July 1, 2024
Just create variant with values TRUE and FALSE, that fix problem!
July 15, 2024
Hey I had the same problem while makink variants and component properties.
First I used this “Boolean Property” But It didn"t work I dont know why.
then I used “Variant property” With true/false an it did work
can some one please tell me why boolean property was not working?
it just hide the layer/variant
Tony_Eneh
July 17, 2024
thank you. This short video clarified it for me
Andrew_Rodin
December 24, 2024
Who developed this feature isn’t designer, the Figma was the best instrument, but just only was… All mates say, that it’s become bullshit
