Matt_W
Sep 6, 2023 12:57 PM UTC
Auto layout makes contents absolutely positioned
I’m loathed to post this because Figma is becoming a time sink and nothing ever gets fixed, sh!t just gets bolted on with very poor testing and planning to avoid fallout. It’s the new Sketch, Photoshop, you name the bloatware, Figma is it.
Having a group elements in a container that i want to apply auto layout to, let’s say a simple row with cells, doesn’t matter. I have the row, I apply auto layout… yet now I have auto layout of one item with the rest being absolutely positioned. The container element with the background and shadow is now within the auto layout and the rest sit on top with some arbitrary position. This is garbage. Manually fixing this retroactively to the elements is a massive waste of time. Figma is becoming a massive waste of time.
There was an update that changed this behaviour. Previously the container element would be applied as the background, and the contents would be auto-laid-out as you’d expect.
Matt_W
Matt_WAuthor
Jan 11, 2024 3:56 PM UTC
@Figma_Moderation Is there a fix for this? This is becoming increasingly annoying, even the simplest of groups, a rectangle with text in it, applies absolute position to the text.
Matt_W
Matt_WAuthor
Jan 11, 2024 3:58 PM UTC
just why?
Jan 11, 2024 10:48 PM UTC
Hey there, so sorry for the delayed reply!
This automatic ‘absolute position’ was a new, expected behavior following Auto Layout updates made in July 2023. It’s automatically applied to elements that are not a frame to maintain formatting. If you remove absolute position, the elements will stack, which will show the previous default behavior.
This change was made to prevent a frame or layout that you’ve already created from visually changing when you apply auto layout. Even if that means that the auto layout settings you’ve applied might not exactly match what you intend. Previously applying auto layout to a rectangle with an element on top would have moved to elements to sit next to each other, so you then had to move them back or adjust your layers once auto layout was applied.
We understand that not every change will fit with every user’s way of working, but we appreciate your feedback on this. We’ll be sure to pass this onto our Auto Layout team to consider for future versions.
Please note that Figma_Moderation is not associated with Figma or our Community moderation team. The forum is primarily run by the community, so if you have an important bug to report feel free to submit a bug report to our support team directly via the form here: https://help.figma.com/hc/en-us/requests/new?ticket_form_id=360001744374
Matt_W
Matt_WAuthor
Jan 15, 2024 3:56 PM UTC
This is the Dreamweaver equivalent of “ApDiv” and the automatic part of auto layout forces a rebuild of the component and slows down the productivity that made Figma great. Not to mention the inspect panel is full of garbage code.
Please can you point me to the Topic that reached this conclusion?
Jan 17, 2024 12:16 AM UTC
We understand your frustration. There is no specific topic we can share asking for this behavior.
Ultimately, it was a judgement call that our Auto Layout team took into account after launching Absolute position in Auto Layout. It was discussed and tested internally that the absolute positioning of a nested frame is a preferable outcome after adding auto layout, because the alternative would shift the overall size of the stack and its child’s position quite significantly.
The team has also confirmed that we’ve received pushback from the community regarding this change, so we can confirm that they’re already actively working on this to ensure a smoother and more efficient experience for our users. While we don’t have an exact timeline we can share, keep an eye out for future releases: https://www.figma.com/release-notes/
Holly_Williams1
Jan 19, 2024 12:05 PM UTC
I keep getting this issue when adding autolayout to two frames. Usually, I would expect the new autolayout frame to hug both elements, and depending on where the two child frames were, they would either align top-bottom or left-right. However the issue I’ve been having is that when I try to add autolayout, the autolayout frame only hugs to one of the frames. This is extremely confusing and I can’t seem to fix it. I can’t seem to get it to hug both child frames without resizing it, however this doesn’t automatically adjust to hug, it just sets it to a fixed height or width.
Holly_Williams1
Jan 19, 2024 12:28 PM UTC
I have figured out the problem - for some reason, when I create these autolayout frames, sometimes ‘absolute position’ gets set for one of the child frames without me pressing it. This must be a bug.
Paul_Morley
Jan 26, 2024 2:48 PM UTC
Hi Dvaliao, i’m not sure this statement is accurate. In this simple example you’ll see I have only 2 shapes on a canvas. No frames at all.
I select both, apply autolayout with kb shortcut the first time and you’ll see that autolayout is applied without absolute position on either item.
Next I undo back to the starting state, nudge the line a bit, select both and apply autolayout again and this time, absolute position has been applied to the line.
I think the system is applying logic to approximate a ‘guess’ as to what the user wants/expects in terms of layout direction… It’s trying to determine if autolayout should be applied with vertical layout, horizontal layout or wrap by default. When the arrangement of objects isn’t clear (enough), it picks the layout matching the majority of the items and places the others using absolute positioning. You can see that happen in this vid.
I suppose this is an elegant solution and in most/many cases users get what they would expect, however when the absolute position outlier logic is applied, it’s definitely NOT obvious to the user WHY or even THAT absolute position has been applied to a subset of items.
Maybe the toast success message could provide a hint.
Just my 3 cents…
Thanks!
Vladimir_Paraska
Jan 30, 2024 12:02 PM UTC
Sorry, but it is a false statement
Here is example of another strange and annoying behavior.
3 object are in straight line, after hitting Shift + A for Auto Layout, one of then has absolute position. Why?
All 3 objects are same size and even there is same space between them, even before applying Auto Layout.
Please add option to disable automatic application of Absolute position.
We do not want automatic Absolute positioning that has no logic.
Hannah_Taylor
Jan 30, 2024 8:46 PM UTC
Just want to add that is also driving me and my entire team crazy. It took my simple Shift A action and added so much extra effort every time. I couldn’t find anything in the forum about it so had made a new post here: Random frames defaulting to Absolute Position when applying Auto-Layout. Glad to see I’m not the only one who has been frustrated about it. Wish they would revert back to the previous behavior 😒
