Assets are rotating
  • April 13, 2024
  • 4 replies
  • 532 views
Hi guys, I hope someone can help me with this please.
I’ve created really simple auto-layout buttons, I’ve tried both with just text + background fill as well as a filled rectangle + text. Everytime I try to insert it into a page, it automatically rotates 90 degrees. The actual component is at 0 degrees but as soon as I insert via the ‘assets’ tab, it rotates it and I now have to rotate each one back. I’m using the exact same method I’ve always used to make buttons yet it keeps doing this.
Can anyone help with this?
tank666
April 13, 2024
April 13, 2024
I did, everything is set to 0
tank666
April 13, 2024
Almost every user I’ve helped with this issue has said that everything is set to 0°, but I’ve always found the opposite to be true.
So, if it is still rotating, check each layer where your object is nested. If you can’t find the rotated object(s), you can always share a link to the file so anyone can help you.
April 13, 2024
Could I have your email please? I’ll send you the link
