Taras_Savytskyi
Dec 1, 2023 1:28 PM UTC
An error occurred while loading the plugin environment
Hi there!
I published a plugin and am waiting for the review.
When I try to launch the In-development version, it starts without any problems, but when I choose the published version (the one in the review), I get: An error occurred while loading the plugin environment.
At the same time, I have another plugin that was successfully published, and I can open both versions without any errors.
Is there something I’m doing wrong, or is it expected to return this error before the plugin is published to the community?
Thank you.
Power Member
Nov 22, 2024 3:53 AM UTC
This might be because of the libraries you are using which might use components unavailable in the plugins VM. Perhaps your prod build config is faulty since even you can’t open the prod version. For the dev version, have you tried turning the dev VM on and running the plugin to investigate this?
Alexis.H
Feb 27, 2025 1:10 PM UTC
UP
I have the same issue for now more 4+ mounth and still no fix, even with a new draft i cant load any plugins.
Dev team look like they doesnt care at all about a major issue ? is figma dead ?
ehsan moradi
May 19, 2025 8:41 AM UTC
UP
I'm not sure if it's alive or dead, but there are a lot of bugs caused by the backend developers in Figma.
Let me help you out, my friend.
The main issue is that Cloudflare is being used without really knowing how it works ( by figma Dev team ).
If you use a VPN from another country, you might be able to get past the Cloudflare firewall and get the plugins working.
