Taras_Savytskyi
December 1, 2023
An error occurred while loading the plugin environment
  • December 1, 2023
  • 13 replies
  • 3984 views
Hi there!
I published a plugin and am waiting for the review.
When I try to launch the In-development version, it starts without any problems, but when I choose the published version (the one in the review), I get: An error occurred while loading the plugin environment.
At the same time, I have another plugin that was successfully published, and I can open both versions without any errors.
Is there something I’m doing wrong, or is it expected to return this error before the plugin is published to the community?
Thank you.
Power Member
December 1, 2023
Have you tried restarting Figma? Stuff like this happens sometimes.
Taras_Savytskyi
December 1, 2023
Yeah, I tried several things, using Figma Beta and Figma Stable version of the app, restarting, logging out/in, restarting the machine, nothing seems to work. The problem persist.
Power Member
December 1, 2023
In this case don’t worry about it, this is likely just a Figma bug (since it’s the environment failing and not your plugin)
Taras_Savytskyi
December 1, 2023
Thank you, Gleb!
December 13, 2023
I faced same problem in Figma while loading plugin. I work online, Do not use any app or Figma software. What can I do now?
Power Member
December 13, 2023
If reloading Figma doesn’t work for you, reach out to Figma support.
December 13, 2023
I don’t reload page when plugin loading. I run and wait for that wedges. it is taking to load minimum 4minutes and then show that error.
cihad
I had the same problem. I’m worried whether it will pass the review or not.
Power Member
January 1, 2024
This is an issue in the plugins engine, not in your plugin, so it should be good.
Abraham4
November 4, 2024
Hi Taras, I am having the same problem. My plugin works fine with the in-development version. But the Figma review team keeps getting errors. The published version does not open as well. Have you had a fix yet?
