Aligning/merging connectors together
I am drawing connectors from multiple sources to one destination. In some cases the connectors align well and merge with each other to form one single line, whereas in this case the lines are not merging together. Either it goes up or down.
Please refer to the screenshot below. I want to merge/overlap these two lines so that appear as one.
Thanks for your help in advance.
Hey @Ashutosh_Bisoyi, thanks for reaching out!
I tried to reproduce this behavior, and to align/merge the connectors together:
  1. Select either one of the connectors
  2. Hover the blue center part of the connector
  3. Click and drag the line to align it into the other connector
Before:
After:
Please note that depending on the connector’s placement on the canvas, one connector may be better suited to align then another. So if the connector you choose does not re-align as expected, try selecting the other connector to re-align instead.
June 20, 2024
Hello @dvaliao ,
Thank you so much for your time and answer.
Definitely, this approach is the expected one, and that works well usually. But in my case, neither of the lines align with the other one even if I try to drag very precisely.
I’m wondering if depends on the placement of the destination and source blocks. This case is rare to reproduce.
Yes - the team confirmed that this likely occurring due to FigJam’s built-in grid snapping. They’re going to work on a fix that should prevent this from happening in the near future - stay tuned!
June 25, 2024
Thank you so much for the update @dvaliao.
