Hi!
Recently I converted the buttons from our design system library into variants.
I have 3 types: Standard button, Buy button and IconButton
After publishing, from other files I can only see the Buy button The other 2 are not available.
However, If I look for the buttons in the system library document they appear in the library and work fine.
Is this a bug? or how can I fix it? it’s really annoying not being able to use the buttons anymore… Thanks!
I have the same problem, some buttons (they have variants) are not showing up! That makes it very unusable for me.
Same here - having this problem on a large scale project as we speak. Can we please get some direction on this?
Thank you.
I had a similar issue. If you select all button components, right-click , then select publish selected components, you should see that some of the buttons have conflicting properties. Then on the right panel, you can click, show me conflicts. Fix these, republish and it will work
