Re-usable container component
Andre4
I’m trying to figure out a workflow where I can make a library of components and re-use. This is all fine and easy for normal components. But when I wan´t a container component (such as a main layout) and re-use it. Then it´s not possible to use the container areas without detaching the main layout component (and thereby loosing all benefits of re-using the component).
Is there a best practice workflow where I can create a handful of “main layouts” then re use them in a lot of pages. Then automatically update all pages when I make a change to my main layout?
Best answer by Shane
Have a look at these two videos to show you the technique to achieve this:
Shane
  • 74 replies
  • July 13, 2021
Andre4
  • July 13, 2021
Worked perfectly, thanks a lot @Shane!
Shane
  • 74 replies
  • July 13, 2021
Welcome Andre 🙂 Other videos in that series are also worth a gander, especially if you’re working a lot with tables.
  • August 12, 2021
