How to set constraints for a layer?
  • January 12, 2022
  • 760 views
Tuan_Au
Hi I want to set constraints for a Text Node but it seems like the property is read-only Constraints · Figma Developers
Also, I don’t find any method or way to set the constraints.
How can I do it?
Thank you,
Best answer by tank666
To change read-only properties, you need to overwrite the entire object or array. In your case, you need to overwrite the object, and the code will look like this:
node.constraints = {
	horizontal: "MAX",
	vertical: "MAX"
Read more about editing properties on the Figma Developers:
figma.com
tank666
  • January 12, 2022
	horizontal: "MAX",
	vertical: "MAX"
figma.com
