Dropdown Menu Not Working
  • February 28, 2023
  • 4 replies
  • 2544 views
Brittany_Ejimole
Hi All,
I hope this isn’t the exact same as another issue someone asked about with dropdown menus, but I can’t seem to get this to work and I would like some help.
I followed the steps in this video:Create a DROPDOWN MENU in Figma (Tutorial) - YouTube
This is my figma file: https://www.figma.com/file/x1Rb2bYD9VlgeJezzF3pNh/Dropdown-Menu?node-id=0%3A1&t=tqRO5EXAJBAvN3xA-1
All the prototype does is change the dropdown arrow from up to down. It’s not acting like it’s one with the list of options. That’s all I’ve noticed. Originally I had trouble even adding the interactions, and I had to move the top row of cities outside the dropdown menu bounding box to draw the connections. Then I moved them back in. Not sure if that is causing the problem.
Please let me know if I’m making any errors.
Thank You!
Best answer by Anelia-IMT
Hello Brittany,
the main error that you were making was that the dropdown list of options was not inside the dropdown component. I fixed it for you inside the file 😉
The list of options has to be inside dropdown_menu, otherwise Figma interprets them as separate layers, and they don’t belong together.
Cheers.
Anelia-IMT
  • 8 replies
  • March 1, 2023
Hello Brittany,
Cheers.
Brittany_Ejimole
Wow, you fixed it! Thank you sooo much!!
Hello,
I’m having the same problem, but when I put the drop-down-menu-options component inside the the dropdown-menu variant frame, it still doesn’t work in prototype.
  • August 24, 2023
This topic was automatically closed 3 days after the last reply. New replies are no longer allowed.
