Complex Button variant and properties
Alek
Hi all it’s been a while since I got to use variants and properties in Figma so I apologies for this simple question.
As per image:
On top the Button component
Down below the component stretched.
I would like to keep the angle/cut of the element 2 when I resize.
I would also like to have color properties changing for element 1 and 3
and also that the button stretches when text is longer
What’s the best approach to do this with variants and properties?
I set property for element 1 and 3 to be shown or not but how can I also add color variations just for those 2 elements?
Thanks
tank666
  • 4869 replies
  • July 2, 2022
In fact, this is not difficult to do. You can see and duplicate my example file here:
Figma – 2 Jul 22
You can change the color as usual—by changing it in the master component or overriding it in the button component or its instances.
Alek
  • July 3, 2022
Thanks Tank666, got it. Basically you assemble the button “css” stile with 3 elements not by cutting the main shape for the button.
Don’t know why but I remembered you could just stop anchor points from moving.
All clear thanks
  • August 2, 2022
