Command to disable snapping
  • February 16, 2021
  • 5 replies
  • 3826 views
Nathan_Manousos
I’m pretty sure holding command while dragging a layer used to disable snapping and smart guides temporarily, but now it shows a little down arrow next to the cursor and does not disable snapping.
Was this an intentional change, and is there a way to momentarily disable snapping?
Best answer by Whit_Gurley
This should be a feature, go vote for it here! 🙂
Josh
  • Former Community Manager
  • 1019 replies
  • February 16, 2021
Are you able to share a screenshot or recording of what you’re seeing?
Nathan_Manousos
Yeah here’s a video Screen Recording 2021-02-16...
Are you unable to reproduce this? You just hold command while dragging a layer and you’ll still see smart guides.
  • 4707 replies
  • February 17, 2021
No, there was no feature like this. You are probably confusing it with holding Cmd/Ctrl when resizing the object to ignore constraints in the frame you are resizing. When you drag objects with Cmd/Ctrl, it forces them to nest in frames underneath, even if the object is larger than the frame. Hence the arrow icon.
Whit_Gurley
  • August 19, 2022
gfiche
  • September 9, 2022
This fonction is available in sketch, illustrator, photoshop, protopie and much more…
Why not in Figma… Essential for sketching icons and tiny symbols.
