Add more programming languages to the Code Block snippet (Java, C#, PHP, etc)
  • November 3, 2021
  • 6 replies
  • 1818 views
Colin_Nickerson
Hey there. Would it be possible to add C# support to the new codeblock thingy? Was a bit sad to see that it was not there when preparing for a C# programmer interview.
lepdev
  • 57 replies
  • November 5, 2021
What ?! it’s pretty incredible to have C++ but not C# nor Java nor PHP 😉
Actually it doesn’t seem to change color syntax when you switch syntax am I wrong ?
Salar_Brefki
I hope add Dart language to Code block
Pawel_Kubik
Hi, the code block is a nice feature. However, I think that there should also be supported Java syntax. Whatever it is, Java is one of the most popular programming languages.
Alexander_Scheng
We are trying use figjam & figma to explain the relationship between the UI and the API request & response. It works great. But, we still need more language supports:
  • yaml: our dynamic configurations are using yaml. it’s quite long, and it’s unreadable without showing spaces and correct highlighting.
  • MarkDown: a famous document language.
Andrew_Kachanov
ten symbols
  • January 11, 2022
