Is this Figma issue or my laptop because all of the other apps are working fine.
  • September 11, 2024
  • 267 views
Asim1
I am facing this blurness issue while using Figma desktop application. Anyone else facing the same issue or does anyone know how to resolve this.
tank666
Alok
  • September 12, 2024
If you’re experiencing blurriness in the Figma desktop application while other apps are working fine, it might be related to specific settings or issues with Figma. Here’s how you can troubleshoot and resolve this problem:
1. Check Display Settings:
  • Display Scaling: Ensure your display scaling settings are set correctly. On Windows, go to Settings > System > Display and check the scaling settings. On macOS, go to System Preferences > Displays.
  • High DPI Settings: On Windows, right-click the Figma shortcut, select Properties, go to the Compatibility tab, and enable Override high DPI scaling behavior.
2. Update Figma:
  • Check for Updates: Make sure you’re using the latest version of the Figma desktop app. You can download updates from the Figma website.
3. Adjust Zoom Levels:
  • Zoom Settings: Sometimes blurriness can occur due to incorrect zoom settings. Ensure you are zoomed in or out to a level where the design appears sharp.
4. Clear Cache and Reinstall:
  • Clear Cache: Figma doesn’t have a direct cache clearing option, but reinstalling the app can help.
  • Reinstall: Uninstall the Figma desktop app and then reinstall it from the Figma website.
5. Check for Graphics Driver Updates:
  • Update Drivers: Ensure your graphics drivers are up to date. This can resolve issues with rendering in applications.
6. Test on Different Devices:
  • Other Device: If possible, test Figma on another device to see if the issue persists.
7. Check Figma’s Community and Support:
  • Figma Community: Search the Figma Community for similar issues or solutions.
  • Contact Support: If the problem persists, reach out to Figma Support for further assistance.
8. Adjust Performance Settings:
  • Figma Performance: In some cases, adjusting performance settings within Figma or ensuring that hardware acceleration is enabled may help.
These steps should help you diagnose and address the blurriness issue with the Figma desktop application. If the problem persists, it may be useful to report the issue to Figma’s support team with detailed information about your system and the issue.
