Figma copy-paste no longer brings in vectors—only images. What changed?
  • July 31, 2025
  • 32 replies
  • 3884 views
sezer
I’m hoping someone can clarify this for me. I used to copy objects from Adobe Illustrator with Cmd +C and paste them into Figma with Cmd +V, and they would arrive as editable vectors. I’m absolutely certain this worked before.
Lately, though, every paste comes in as a flattened image instead of vectors. Nothing in my workflow has changed, so I’m starting to wonder if I’m losing my mind!
Has Figma (or Illustrator) changed something recently? Is there a setting or workaround I’m missing? Any insight would be greatly appreciated.
Thanks in advance!
Best answer by djv
Hey All, thank you for your patience while our team worked towards a solution with Adobe!
Adobe identified the root cause and now have a fix in place. The issue stems from a code change introduced in version 29.8.x and is not related to the recent SVG settings change. They also confirmed the exact repro: the issue occurs when the SVG “Minify” option is enabled.
They will be disabling the feature flag associated with this code change and will let us know once it’s complete. After the flag is turned off, you will need to restart the application and Copy/Paste with the Include SVG setting enabled to ensure it will work as expected.
You can find the setting under File > Export for Screens, and hit the little settings icon in that Dialog...go down to SVG and uncheck minify (until the fix has been fully rolled out by Adobe).
Steveagaba
  • August 5, 2025
The problem is not with Figma, The problem is with the Adobe illustrator update you just installed recently, Illustrator 29.71, Uninstall it and go back to the previous version, All will be fine.
JLarts
  • August 6, 2025
Thank you! I thought I was going mad… What the f* Adobe lol…..
You think this will get fixed?
Thanks again,
Jonny.
Junior Rodríguez
I solved with  Preferences > Clipboard Handling> check Include SVG Code
ProUser1
  • August 7, 2025
You're right — this used to work. Copying from Illustrator to Figma via Cmd+C / Cmd+V previously pasted editable vectors, but now often results in a flattened image.
What's changed:
  • Recent updates in Illustrator and possibly Figma have altered how clipboard data is handled.
  • Illustrator may now prioritize image data in the clipboard.
  • Figma sometimes pastes the image version instead of vector data.
Workarounds:
  1. Export as SVG from Illustrator, then import into Figma — this preserves vector paths.
  2. Enable AICB clipboard format in Illustrator under Preferences → File Handling & Clipboard. Check both “AICB” and “Preserve Paths.”
  3. Use older versions of Illustrator (pre-2024) where this behavior still works.
There’s no official fix yet. Using SVG export is currently the most reliable method.
Gayani_S
  • August 8, 2025
Hey everyone, thanks for flagging this! This change is due to the recent Illustrator update (version 29.7.1). Head into Illustrator’s general settings and make sure “Include SVG code” is checked under Clipboard Handling. Once that’s enabled, vectors should paste as vectors again.
Let me know if you this is not working for you, happy to help further!
hivajo
  • Active Member
  • August 9, 2025
I’m hoping someone can clarify this for me. I used to copy objects from Adobe Illustrator with Cmd +C and paste them into Figma with Cmd +V, and they would arrive as editable vectors. I’m certain this worked before.
Has Figma (or Illustrator) changed something recently circle of influence? Is there a setting or workaround I’m missing? Any insight would be greatly appreciated.
Thanks in advance!
Figma and Illustrator haven’t officially changed this, but Illustrator’s clipboard settings might affect it. To keep vectors editable when pasting, enable “Copy as SVG” in Illustrator’s Preferences under File Handling & Clipboard. Alternatively, export your artwork as an SVG and import it into Figma. Direct copy-paste sometimes results in flattened images due to how clipboard data is handled. Updating both apps to the latest versions can also help.
laurel.ch
  • August 11, 2025
Wow. ANOTHER bad interface change from Illustrator? I’m kinda shocked. It’s like they insist on ostracizing the longtime users for the sake of users who are going to be too confused to use it anyway. They need to STOP.
ksn
  • August 12, 2025
Hey all - first, sorry for the disruption this may have caused you. We worked diligently to make sure this got addressed asap, and Dylan posted some info here (if you haven’t already seen it): https://x.com/zoink/status/1955105303931843008
I hope this is helpful for you -- let me know if you continue to have issues.
GxC
  • August 20, 2025
Thanks Gayani. You made my life easier
spds
  • September 17, 2025
Hi yall, the ai svg setting fix doesn’t solve the problem
Brian_Olson
  • Active Member
The Illustrator setting did not fix the issue.
Brian_Olson
  • Active Member
I can paste from Illustrator into XD and Powerpoint as a vector.
This is an Figma issue.
Brian_Olson
  • Active Member
  • September 19, 2025
Hey All, thanks for chiming in here!
It looks like the solution suggested was working at the end of August, but not recently.
When did you both notice this happening again? Was it ever working as expected even before this topic was started in late July?
With more context, we can try to flag the team to see if this is a new bug or a regression from the previous one.
macamrstudios
  • September 23, 2025
Something must have changed (in Figma) as selecting the above option no longer works. It worked two weeks ago, but now it does not. The only way I have found you can get an eps file into Figma is to now use a plugin and most are paid.
Brian_Olson
  • Active Member
Pasting vectors did not work for me as of at least 10 months ago.
Thanks for following up ​@macamrstudios and ​@Brian_Olson
I flagged this to the team to investigate, and they discovered that this is a new issue with Illustrator 29.8.1
Our fix in August was for the previous version of Illustrator, but now, it seems that copy/paste is broken entirely, even with the checkbox on for include svg.
As a new temporary solution, if you want to get contents out from illustrator and into Figma, you will need to export as SVG and then drag the SVG into Figma.
  • September 25, 2025
Hey ​@spds, ​@macamrstudios, and ​@Brian_Olson,
Thanks again for your patience and understanding while our team tries to get this fixed!
We are now working together with Adobe to try and pinpoint the issue, and Adobe is wondering if we could get the following details from any of you who are currently experiencing the issue:
  1. Operating system and version
  2. Figma version
  3. Adobe illustrator version
With these details, we’ll hopefully be able to successfully repro to see what ultimately caused this issue.
mudasir_qayyum
You’re not imagining things — this has changed recently. Figma used to handle copy/paste from Illustrator as editable vectors, but after updates on both the Figma and Illustrator sides, that direct vector paste isn’t consistently supported anymore.
A couple of workarounds you can try:
  • SVG route: In Illustrator, copy your objects, then go to Edit → Paste Special → SVG Code or just export as SVG and drag/drop it into Figma. That will keep them fully editable as vectors.
  • PDF copy: Some people have had luck copying via PDF format (in Illustrator: Edit → Copy As → PDF) and then pasting into Figma.
  • Drag & drop: Export your Illustrator artboard as an SVG and simply drag the file into your Figma canvas.
It’s a bit less seamless than the old Cmd+C / Cmd+V workflow, but it ensures you still get clean, editable vectors instead of flattened images.
Brian_Olson
  • Active Member
  2. Figma version
Thank you for working on this! :)
1. OS and Version
Edition    Windows 11 Enterprise
Version    24H2
Installed on    ‎11/‎19/‎2024
OS build    26100.6584
Experience    Windows Feature Experience Pack 1000.26100.234.0
2. Figma Version
Figma Desktop App version 125.8.8
3. Adobe Illustrator Version
29.8.1 (64-bit)
Thanks, ​@Brian_Olson
I’ve sent this over to the team to try and duplicate using your same specs. So far, the teams have only seen the issue on macOS, so good to know that you’re using Windows. I’ll report back as soon as we know more!
In the meantime, the teams found another temporary solution. While not ideal, but if you go to: Preferences > General > Reset preferences in Illustrator, copying and pasting into Figma will begin to work again.
Brian_Olson
  • Active Member
  • September 26, 2025
Thank you for passing that along djv.
Resetting preferences in Illustrator did not fix vector pasting for me.
Thanks for trying, ​@Brian_Olson
Can the team get a copy of your illustrator preferences folder? This will help us work with Adobe to track down this bug.
It's located in: %AppData%\Adobe\Adobe Illustrator <version> Settings
Just zip up the folder and send it over here: https://help.figma.com/hc/en-us/requests/new?ticket_form_id=360001744374
If you can let us know the ticket number, we’ll make sure it gets routed to the right team - thanks again!
Brian_Olson
  • Active Member
Done. I did not get a ticket number. Just a toast saying submission was successful after a redirect to help.figma.com
And no worries - we got it! (Ticket #1525635 for your reference.
