Disable padding on exports
  • February 27, 2025
  • 92 views
sdafkjhasdkjfhas
Please make it possible to disable white space padding on exports. Look at the attachment, this is just a single square and exported so much white space is added. I don’t want any white space, let alone this much.
  • February 27, 2025
Hey there,
Is it happening on Figma or FigJam?
If the issue occurs on FigJam, please check our response below in this thread:
(The extra padding is the expected behaviour for FigJam. As a workaround, in FigJam you can also right-click on an image to ‘Copy as PNG’ > select ‘Transparent’ background which should not have any padding applied.)
If this happens in Figma, can you please check that you're selecting only the asset you want to export, not the entire frame, before exporting?
Example:
If you are still running into issues, I’d suggest reaching out to our support team for further investigation here: https://help.figma.com/hc/en-us/requests/new?ticket_form_id=360001744374
When filling out the form, please use your Figma email account, provide a link to the file and add support-share@figma.com as an Editor, so they can take a closer look and try to replicate. Thank you!
