Is it not possible to set a text variable to an empty string?
  • September 1, 2023
  • 11 replies
  • 3410 views
Alex_FG
I can set it to ’ ’ (a space), or any string with text in it, but nothing happens if the value I give it is ‘’.
Best answer by Alex_FG
I think I was setting it to null instead of ‘’. Setting it to ‘’ worked.
Alex_FG
  • September 1, 2023
nvm it’s a bug on my end 🤓
  • September 5, 2023
Hey! How did you fixed it? I have the same problem 😦
Alex_FG
  • September 5, 2023
Martin_Mateos_Sanchez
Hello! Which ASCII character are you referring to as ‘’? Right now, I can only set it to a whitespace for the variable to appear as empty (although it isn’t, since it’s a whitespace and has a length of one)
Captura de pantalla 2024-01-06 172436
tank666
  • January 6, 2024
You need to set it to an empty string without any character.
variable = '';
Oh, is that using the API? Or is there a way using the keyboard? Because if the variable is set to a whitespace and I delete it and press intro, the variable resets to the whitespace. Similarly, if I create a new text variable, which by default is set to “String value” and I try to delete that completely and press intro, the variable resets to “String value”
So weird
tank666
  • January 6, 2024
Only using the Plugin API. I wrote about it here:
  • May 6, 2024
Hey, I am not able to do it. Can you explain it a bit more ? How do I set a string’s value as null
tank666
  • May 6, 2024
You cannot set null as a value for a string variable. Instead of null, you must specify an empty string.
variable.setValueForMode(modeId, '')
Joseph_Kaguri
Hi, could you share the full code that you added on Run plugin API to set a String variable empty?
tank666
  • November 4, 2024
const collection = figma.variables.createVariableCollection('New collection'),
    modeId = collection.defaultModeId,
    variable = figma.variables.createVariable('New string variable', collection, 'STRING');
variable.setValueForMode(modeId, '');
This code will create a new collection with a variable with an empty value.
