Icon Color Update Issue in Button Component Instances
  • February 6, 2024
  • 460 views
Marlon
Hello, I have several icons, named as “Vector”.
I also created a button component with a nested icon. When I change the icon of a Button instance, the icon color changes correctly.
The problem arises when I want to update or change the icon color in the main component, it does not affect the button instances and I have to reset the component and change the icon again
It is somewhat non-scalable if the button component has been implemented in different parts of the project.
I would appreciate it if you could help me solve the problem.
  • February 7, 2024
Hi there,
Thanks for the post! It looks the same issue with this: Nested components in swapped instances are bugged?.
Our engineers are looking into this. I will get back to you once we have any update that I can share with you.
Thanks for your patience.
Toku
