Incorrect text styles in dev mode
  • March 15, 2024
  • 219 views
Anastasia_Lavrentiy
In design mode, the text style is displayed as H4, in Dev Mode it is displayed as H3. How can this be fixed?
Celine_D
  • 3381 replies
  • March 18, 2024
Hey Anastasia,
Sorry to hear this is happening! This looks odd, I can’t replicate on my end. When I applied any text style such as H3, in Dev Mode , it displayed the right text style (H3).
Can you try first to clear out your cache (here the steps how to do it) and force-quit in your browser or desktop app to see if that helps?
If this doesn’t help, I’d like our team to investigate further. If you are hesitant to share your file publicly here, please reach out directly to the support team with a copy of your file: here
Our technical team can have a look at it
Be sure to use your Figma account email, include a link to the file, and share it with support-share@figma.com so they can take a closer look. Thank you!
Nelly2
  • August 5, 2024
Hello here!
I’ve found a 3 years old topic here and the problem is being reproduced until now
Maybe it’s time to fix the bug? Cleaning cache didn’t help and solving the issue with support team via email can take weeks 🥲
Celine_D
  • 3381 replies
  • August 5, 2024
Hey there! Thanks for flagging this, and I understand your frustration.
I see in the backend that the issue has been solved for @Anastasia_Lavrentiy by the technical quality team with this workaround:
’ Can you try making a ‘silent’ change to the text style and then publishing and accepting the update? To do this, select the text style and make a minor change like adding or editing a description and then publish and accept the update. ’
If this workaround doesn’t help, it would be great to have access to your file, so the team can try to replicate and investigate it further by filling this form here as mentioned. Rest assured, our support team will do the best to investigate your case, and sorry for the delay in our response. Thank you 🙏
