Need to export all of a frames contents to png, not just the contents in it's viewport
  • July 17, 2024
  • 694 views
I have a frame which contains content which is twice the height of the frame, with vertical scrolling enabled for overflowing content.
Using the rest API, I want to be able to export the frames entire contents as an image, not just the contents visible in the frames bounds. I have tried various combinations of the documented ‘use_absolute_bounds’ and ‘contents_only’ parameters with no luck, the exported image is always cropped to the dimensions of the frame. Any ideas?
Many thanks
Best answer by djv
Hey @Damon_Simmonds, thanks for reaching out and sorry for the trouble!
Right now, this is expected behavior. It’s not possible to export a scrollable frame’s contents. Exporting will exclude any objects in the exported frame that are outside its frame.
This is on our radar for future improvement though:
  • July 20, 2024
@dvaliao Thanks very much for the response. Keen for this!
