How to preserve icon color override and size?
  • March 4, 2021
  • 25 replies
  • 16334 views
Yuan_Chang
I have been trying to find a way to preserve the icon color override within my button component. As you can see here, I used the trick from Rogie (Perserve Icon Color Override) to apply union to the icon, and everything seems work.
Screen Shot 2021-03-04 at 8.24.52 AM
However, now when I swap an icon, the union makes it hard to control the icon size (even though all icons have a frame 24x24, the content inside are vary). It then affects the auto layout and size of the component. Therefore, I tried to add another frame to contain the union layer and set fixed size, but it still didn’t work at all.
With the old approach, which I have to change the color every time, it allows me to constrain the icon size within the button to be 16x16. I am wondering is there a better way to preserve both color override and icon size?
tank666
  • March 4, 2021
What if only the icon was wrapped in a union, and not the entire component?
Screenshot_20210304-203030-01
You can see this file:
Figma
  • March 16, 2021
Thanks @tank666 for your file.
I have two large libraries I’m managing for my team (one for icons, one for UI components) and was struggling to make icon colors work for both dark and light theme for several hours this afternoon. Here’s what worked for me:
  1. Do the Union trick from Rogie’s file: for me, I duplicate my expanded icon in place (cmd+d), then union the two dupes, delete one of them, rename the union item to something like “color_fix”, the icon vector itself to “Union”, and the frame containing it all to the name I want for the icon (e.g. “keyboard”). Convert this to a component if it isn’t one already.
  2. Make sure all the items are set to Scale for height and width
  3. Make sure no color styles are applied anywhere in the stack; just some generic black color or whatever
  4. Publish the icon library
  5. Accept the icon library updates in the UI components library
  6. In the UI components library have a component with two icons in it, one for light theme and one for dark
  7. Use those icon components throughout the UI components library file.
  8. Apply the colors you want to the light icon and dark icon (I applied the color on the level of the item labeled “color_fix”)
Doing all of that enabled me to actually see the icons scale correctly to several different sizes within different components and also reflect the correct color depending on which theme the UI component pertained to.
Yuan_Chang
  • March 17, 2021
Thanks for the advices above. I actually remade all of my buttons 😅 in order to fix the icon size. One thing I learned is that Rogie’s trick works, but it’s very important to set a frame for the icon first rather than having the union then create a frame to wrap it.
KubaA
  • March 24, 2021
I must say that this sounds like a workaround to a bug. Wondering if this will be fixed soon as it makes using variants and interactive components nearly pointless when there is an icon-placeholder
Update: problem fixed with naming each shape for each icon with the same name. Color override works properly now. There is no bug.
Timj
  • March 30, 2021
Variant icon color not being static is definitely a bug. I’m totally against hacks like this as it complicates the components, I remember the Sketch icon masks I had to maintain.
  • April 1, 2021
I don’t like hacks either, but I do like that my icons are now getting the right color for each theme, even when I override the icon selection for, say, a button. My update to this thread is that I now am no longer using an icon component with a dark and light version; I’m just letting the parent component (say, the button) do the color overriding and it seems to be working. I probably don’t need the icon container anymore, but I also don’t want to touch it because it’s working.
ash
  • August 3, 2021
thanks KubaA, this is definitely the best way to address preserving icon colors! 💯
Jakedeg
  • August 12, 2021
Seems like it will also work to use a modified version of Rogie’s trick where you put a union within each icon component rather than within the button component that contains the icon. I think I prefer that way, since they’re already framed, and I don’t have more nested components to click around in my button. I almost never have to dig deep into the icon component itself, so the union there is mostly out of sight, out of mind.
Tobias_R
  • August 20, 2021
This was 100% the answer. My team uses FontAwesome as glyphs… So we originally had every layer named the FontAwesome html (far fa-icon-name) so devs would know which icon to use exactly. Just had to copy/paste that into the Description instead and then rename all the layers to the same name: “Icon”. Works perfectly now!! Thanks so much 🙂
Menno_Weerepas
It’s all in the name. I just found out 🤦‍♂️. over 500 icons in our DS each one of them in a symbol 16 x 16 with a unique name off course. But the element inside could have different names like “vector”, “union”, “primary”, or whatever. Once I noticed that elements with the same name didn’t switch color I’ve named every element “vector” and it works. Now I have to change this hack back again 🤦‍♂️
Jesse_Payne1
Have just implemented this trick so I can put up icons with hover states with the new interactive components. Kinda annoying because I’m going to have to slowly replace all my icon buttons across almost 100 files.
…So wild that this is so similar to something we used to do in Sketch to get colour overrides to persist in 2016/17.
Andrew16
  • November 24, 2021
I am still having problems with this. Keeping the icon layer name trick as @KubaA advised all the same within the .base / parent master components still doesn’t retain overrides…really frustrating…
Double triple handling entire design systems here we go.
AlicePackard
  • Active Member
  • November 24, 2021
I’m having a hard time understanding what Rogie’s set up offers that is different or better than using overrides and swapping with a simple flattened vector:
Screen Shot 2021-11-24 at 8.14.47 AM
This ☝️ is not a union, it’s just a vector in a main component frame. The main component is named after the shape, and the vector nested within is named “Icon”, and this naming structure is what allows us to override an icon’s color (at the “Icon” layer level), swap the component with another, and that overridden color will persist after the swap is made.
Here’s an example of this happening when the icon is nested inside a component like a button. I used Rogie’s file in this example:
icon color swap
✔️ The pink color override persisted after I swapped because the vector layer inside the icon component shared the same name and structure.
✔️ The size of the icon persisted after I swapped because it’s following the size I set in my button component. All the original icons in Rogie’s file are 39x39px, and you can see I shrunk this down to 21x21px for my button component.
If I’m misunderstanding the use case for Rogie’s method I’d appreciate someone letting me know 🙏 I was surprised to see this thread for a lot of the reasons folks have already mentioned: this method reminds me of what had to be done in Sketch, and I very much don’t want to return to that world 😅
If folks would find it helpful, here’s a view-access link to the Figma file I used to create those screenshots and GIFs to get a closer look at the layers and whatnot.
Roman_Victorovich
doesn’t work
YuanChang
  • May 31, 2022
It looks like the new update allows people to use same layer name + structure to achieve it
Alexandre_Istrasoft
for any components, to preserve override properties when switching, the layer STRUCTURE and NAMES of all layers inside all switchable components need to be IDENTICAL
Sam18
  • September 22, 2022
Also unable to make this work. All icons have the same name, unionized the icons in the icon library and still not working. When I change state or theme (colour) using properties, the icons remain the origin colour.
tank666
Could you share a link to an example file?
Matthew_Ortega
To be honest, it seems like a lot of people in the Figma community get excited about hacky workarounds to things that should be straightforward. As a design system maintainer, I get a lot of complaints over things like this, and there is no reasonable way to solve them. Most designers won’t learn the hacks.
Dan15
  • December 7, 2022
Thank you @Matthew_Ortega ! It’s ridiculous that you should need plugins / hacks etc to do something that is web standard. Icons should inherit component / variant styles. Just like text.
Figma’s problem here is that they’re treating icons like just another component, when anyone who has ever been on the internet can see they’re not buttons or fields etc. They are a language, just like text.
Sometimes I swear the figma designers don’t think like designers at all.
Dan15
  • December 7, 2022
Also, just fyi as a vet with 17 years design experience and who builds libraries every other month - these hacks don’t work. They work in specific cases for small libraries with zero variants or states.
Jairo
  • January 5, 2023
Hello, i would like to share my two cents on this topic in hope it helps someone.
Figma – 19 Dec 22
This is a file i created to explain the problem where you can have a component with an Icon and some text, and how when you manipulate the icon within another main component, it no longer switches variants correctly.
However, if you change the icon on an instance of the second main component, then it hovers correctly.
(I am super bad at explaining, you better grab the file and see it yourself.)
Thing is that i reported it to customer care, and it is a known bug that may (or may not) be fixed this month.
Dominic
  • Active Member
  • January 9, 2023
This is a known bug for ages. I recently came back to a previous design system that was working 100%, only to now have same issue again.
My solution (to the solutions mentioned in thread link below) was to Reset all changes to the icon components (layer) in my button masters, dropdowns, menus etc… I then had to set icon sizing inside them to where it was before. Luckily I use master componentents, but this is an embarrassment that Figma hasn’t fixed this, or worse patronizes professionals saying that it has.
Check out this thread if you haven’t tried the layer naming, unique color for icons set stuff first:
Mike_Escoffery
  • September 14, 2023
This isn’t an answer to the original problem. You’ve changed the colour on the Instance level of the button. If you swap the icon to a different one, it does retain the colour of the current instance.
The scenario we are trying to solve is to recolour the Master Component Icon colour, and have it update every single instance of that component. So If I have a Car Icon in my master component, then create an instance of the master and change the icon inside the instance to Dog. Now go back to the master component and change the colour of the car. The Dog instance remains in it’s old colour, even thought we didn’t override the colour in the instance.
Sebas
  • March 18, 2024
That update is the real solution!
I had to revise each vector object in every main component, flatten them, give them the same name, and make them the same color variable.
After that, they all worked 😃
@KubaA, u da real MVP
