No variables available for line-height property?
  • May 27, 2024
  • 230 views
I can not connect the {line-height} property to a local variable {number} anymore.
It shows the message “no variables available”
All the existing styles with a line-height property in this file are connected to a variable, but if i want to change an existing one or create a new one - it shows this message
Is this a bug?
When i recreate in a new blanco file and just connect line-height to a variable it works.
Best answer by FilipaGo
Hi @Jean-Paul_Pacque
Check this topic: Text Line Height Variables Scoping
Hope it helps 🙂
FilipaGo
  • May 28, 2024
Hope it helps 🙂
Yes. Thank you! This fixes the problem. They are only showing for ‘Line height’ if I have ‘Show in all supported properties’ selected.
