Getting export settings from the main component in a team library
  • July 21, 2024
  • 93 views
BrickBuiltBen
Please excuse me…I’m not a professional developer. I’m trying to write a plugin that is able to find the export settings (set by the user in the app) of a component in a team library when I pull an instance. In the console, I get [object, Object] for mainComponent.exportSettings:
figma.on('selectionchange', async () => {
  const selection = figma.currentPage.selection;
  const instance = selection[0];
  if(instance.type === "INSTANCE" && selection.length === 1){
    const mainComponent = await instance.getMainComponentAsync();
    if(mainComponent){
      console.log("Main component: " + mainComponent.parent?.name);
      console.log("Main component's export settings: " + mainComponent.exportSettings);
      figma.closePlugin();
I’d really appreciate any help, especially if it’s accompanied by a good explanation (since, I’m trying to learn this stuff). Thanks!!!
BrickBuiltBen
  • July 22, 2024
I figured out that my code IS actually working! The “mainComponent.exportSettings” might have been showing up as just [object, Object] in the console, but if I had actually applied those exportSettings to my instance, I would have seen that they carried through. Duh. Sorry.
A thing I discovered that may be of interest: When you change the export settings on a component, or a variant in a component set in a team library, it doesn’t register as publishable. The library shows “no changes” when I went to publish. I had to make some other change, like a color or something, for the changed export settings to publish along with the rest of the library. Weird.
