Can Connector line objects from Figjam be searched in the layers panel in Figma?
  • July 2, 2024
  • 87 views
gengeng
After copying and pasting Connector line from FigJam into a Figma file, searching for “Connector line” in the layers panel does not return any results.
When annotation text is added to the lines and searched, it matches as Text.
What I want to do is to select Connector lines in bulk in Figma.
Best answer by djv
Hey @gengeng, thanks for reaching out and sorry for the delayed reply!
This isn’t currently possible. It’s most likely due to connectors not being available yet in Figma.
Searching in the layers panel only detects your text connector, because you added “text” to it. With this in mind, you could add text (anything that you want to use as an identifier) to your connectors and then search for them that way as a workaround.
  • July 10, 2024
