Creating a Carousel in Figma
  • June 29, 2024
  • 813 views
Gareth_Rafferty
Hi, I’m creating a sliding carousel where the main item is larger and none blurred. I’ve designed 5 frames for the 5 items but I can’t get them to link up on prototype. All of the carousel items and collection of items are set to Auto Layout.
Does anyone have any ideas how I can get this to work?
Let me know if you need more info.
Vishal_Ramawat
What interaction are you using? You can select the carousel and apply on drag interaction to it, navigate to next frame and use smart animate animation.
If you can share the link to file/ page that would be helpful.
Gareth_Rafferty
Right now it won’t even let me link anything up. Here’s the link: https://www.figma.com/design/hNqGwEf7ofc8BHGwfiB3W3/Macros-Wireframe?node-id=0-1&t=SPYC03NF2lUJnGzc-1
Thanks
Vishal_Ramawat
You have components and instances on the same frame.
Create a new page called Components. Move your components there.
Use their instances in your frames (copy component, paste in your frame) or add from Assets > Local Components
Checkout the file in this comment if it helps further.
