Fixing the hat
  • March 3, 2023
  • 7 replies
  • 667 views
How do I make the frame increase when I open the cards so that I can scroll. I know that you can add autoleiut on the main frame, but then my header is not fixed (part of the header from the iPhone, the header and carousel)
Best answer by tank666
tank666
  • March 3, 2023
Thank you very much, this is the second time you’ve helped me 😃
Do we have to add indents to everything below the header after we have added an absolute position to it?
tank666
  • March 3, 2023
Yes, you need to add a top padding for the content so that the object fixed at the top does not overlap it. Or, instead of padding, you can add a transparent object that matches the height of your header.
То есть это должно выглядеть как то так ?
но тогда что мне делать с этим индикатором ? у него нет параметра Fix если я накидываю автолейаут на весь экран
tank666
  • March 4, 2023
