Component breaks down when part of a parent
  • May 10, 2024
  • 89 views
Hi! First time I write here. I am having an issue I can’t solve.
I have a component that does not display right when I click it. It is inside another component. But when I take it out of that parent component, it works fine. So the problem is not in its construction. The problem is related to it being inside the other component (my nav bar). I leave an image image to show the problem. Thank you all for your help!
  • Figmate
  • May 14, 2024
Hi @Dario_Zarlenga, Thank you for reaching out and sharing your screenshot with us.
I noticed the overlapping objects under ‘Qontact,’ and I assume this isn’t the behavior you are expecting. Also, thanks for taking the time to troubleshoot this issue. If the instance itself works fine, but the issue arises when it’s nested inside a parent instance/component, this might related a bug.
I recommend contacting our support team for a more detailed investigation here - https://help.figma.com/hc/en-us/requests/new
When you contact our support team, please provide the following details to help them assist you more effectively:
  • Please use the email associated with your Figma account.
  • Please include a direct link to the file and any related library files and invite support-share@figma.com to those files with “can edit” permissions. Don’t worry, this won’t affect your billing.
  • Please attach a video that demonstrates the issue, along with explanation. Please use the actual names of the components or instances involved in your explanation. This will help our support team quickly understand and address the specific settings in your file.
Thanks again for bringing this to our attention!
If anyone in our community has additional insights or workarounds, please feel free to share them here.
Thank you,
