Bug: Adjusting one of the dimension of a scaled instance in the right panel changes the other
  • May 18, 2025
  • 67 views
senurich
Steps to reproduce:
  1. Create an instance of any component.
  2. Apply a scale transformation to it.
  3. Modify one of its dimensions in the right panel.
  4. Observe how the other dimension changes.
Tom Reem
  • Figmate
  • June 3, 2025
Hey ​@senurich, thanks for flagging this and outlining the steps to reproduce this bug.
I’m checking in to see if this issue is still coming up. I tested on version 125.4.9 of the Figma Desktop app and wasn’t able to reproduce — resizing in the right panel worked as expected on scaled instances in my test file. If the issue persists, please make sure the app is up to date.
If that doesn’t resolve it, here are a few things that would be helpful to check:
  • Are any overrides applied to the instance?
  • Is auto layout applied?
  • Is fixed width or height enabled?
  • Does this happen in the desktop app, the browser, or both?
Let me know what behavior you’re seeing and what you expected instead — happy to help dig in further. 🙏🏻
senurich
  • June 3, 2025
Hey, Tom.
Using lates figma client. I’ve attached a gif with minimal repro.
Tom Reem
  • Figmate
  • June 4, 2025
Hey ​@senurich, appreciate you confirming and for providing the GIF — very helpful. I followed along and when I drag my cursor over width field under Dimensions, the copied rectangle width adjusted horizontally.
Definitely want to take a deeper dive into the cause. So that we can make sure this gets sorted out, please reach out to our Support team and include:
We’ll keep watch for any other related reports in the meantime. For anything else, keep in touch here.
